Here we go again! Crank no start - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-03-2013, 04:42 PM Thread Starter
05 6.0 165000 miles fresh HPOP,stand pipes,dummy plugs,fuel pump.EGR delete
Was running great on a 82 mile trip was half where there n ABS light came on then CEL and wrench light,came out of O.D. did this for a couple miles several times then cleared up! Got to Miles city had the alternator checked,bad diode so I replaced it and got back on the road to the camp,made it back 80 miles n 2 miles from the camp the ABS n all the lights came on again cleared out when I made it home. Shut it off and started right back up,shut down again n waited a few mins started up but took longer than usual.
Came out the next morning will turn over but no start,tried to clear KAM the next day but no luck.
Has anyone else had this problem? About a month ago I stopped for an hour on a daylong trip,came out to start truck and no start,waited 5 mins spun it like crazy n it catched so I drove the last 600 miles to the job. No problem until this happen.
Any help please?
wildchild200 is offline
post #2 of 15 Old 06-03-2013, 04:44 PM
I know this is frustrating.
Trust the work that was done and get a scan tool on it.
Verify icp, ficm voltage, fuel pressure, oil drainback.
Report back
cfd_shop is offline
post #3 of 15 Old 06-03-2013, 04:52 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
^^^Agreed, may be something stupid.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #4 of 15 Old 06-03-2013, 04:58 PM Thread Starter
I trust the work implicitly as I did it all myself and have been a mechanic all of my adult life.
Within the last month installed new HPOP,stand pipes and dummys plugs, IPR,HCFM, FICM was reading over 48 volts 4 weeks ago .
Unfortunately I am in the wilds of Montana working and the closest town is 30 miles away and I do not have my scan tool available !
Just thought it was really odd that the ABS,CEL, wrench light and TBC fault would flash like it did ,so this is leading me to believe that it is an electrical problem of some sort and that some one else might have had the same issue before.
Would a bad VSS cause a no start condition, I know it will make all the warning light display like they did so I am leaning toward that.
post #5 of 15 Old 06-03-2013, 05:02 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
did you disturb any electical connectors on the driver side, i remember when i did my studs i had a connector that wasnt fully seated causing a no start, maybe check for wire chaffing. It does seem electrical to me.
roche837 is offline
post #6 of 15 Old 06-03-2013, 05:02 PM
Thinking more engine ground, or hot feed to fuel pump etc.
Ground on frame near abs and fuel pump etc.
Check there visually.
You may have to bit the bullet and make the 30 mile ride it may be quicker
cfd_shop is offline
post #7 of 15 Old 06-03-2013, 05:12 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
forgot about the ground, also check the one from passenger side firewall to rear passenger head, this reaked havoc on my buddies 01 v10 but we finnally figured it out.
roche837 is offline
post #8 of 15 Old 06-03-2013, 05:14 PM Thread Starter
Yep gonna crawl under as soon as it ever quits raining and look at the cab ground. The one off the battery to the inner fender looks in good shape and guys this truck is is in great shape, you can eat off the engine,no rust or corrosion, terminals are all clean but did stick the volt meter to the batteries ,across the posts I am getting 12.36 n 12.34 on the batteries, that is low I think ,thought they should be above 12.5 or 12.6?
post #9 of 15 Old 06-03-2013, 05:24 PM
The B+ seems ok for now.
Lets look at pdc and grounds
cfd_shop is offline
post #10 of 15 Old 06-03-2013, 05:40 PM Thread Starter
Ok if it lets up outside I will try to look at the grounds tonite, if not it will be after work tomorrow after 5. i will post up then!
At least I am at a man camp and the powerhouse is literally across the street,so I am not missing out on work LOL.
