Turbo Whine/Squeal - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-03-2013, 04:14 PM Thread Starter
usmcknight69's Avatar
Turbo Whine/Squeal
Recently got my truck back from Ford after doing a head replacement, and now it has a weird whine/squeal sound coming from under the hood. It is louder when the truck is cold and actually traveling down the road. It does not make the sound at idle. Seems like once the truck warms up, the noise becomes less noticeable. Ive checked the firewall area and dont notice any soot, so i dont think it is the up-pipe leaking. All the boots seem to be fine. Im inclined to believe its the turbo. Would the noise happen at idle if it was the turbo if i increased the rpm's while at idle?? Is there a way to rule out the turbo or pinpoint that to being the problem?? There is no loss of power or boost whatsoever! Thanks in advance!
***MOLON LABE***
2005 F250 SCREW LARIAT 6.0L
ARP STUDS, GASKETS, SCT CUSTOM, AFE STAGE II
10" LIFT, 38X14X24 KUMHO MUDDERS
MKW WHEELS, AMP RESEARCH STEPS
4:56 F/R GEARS, 5% TINT, CLAYMORE HITCH
PHANTOM II VOLTMETER, BOOST, EGT
TRANS TEMP, 2 12" KICKER COMP SUBS,
PIONEER AVIC Z130, RECON TAILS, 3RD BRAKE &
CAB LEDS, HID 6000K HEADLIGHTS & FOGS
UPFITTERS, EXTANG REVOLUTION LO PRO, MBRP DUALS
W/O CATS
usmcknight69 is offline
post #2 of 8 Old 06-03-2013, 04:49 PM
Really sounds like a boost or drive pressure leak by description.
Small reed valve sounding like noises can be difficult to find.
cfd_shop is offline
post #3 of 8 Old 06-03-2013, 05:06 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
check the manifold bolts to the up pipes, they usually get loosened to wiggle stuff around under the hood, possible they werent tightened fully. Check the marman flange clamps also
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #4 of 8 Old 06-04-2013, 06:52 AM Thread Starter
I'll check it out when I get home. Is it safe to say that if I'm not losing boost or power that it is not the turbo?
Sent from AutoGuide.com App
***MOLON LABE***
W/O CATS
post #5 of 8 Old 06-04-2013, 06:57 AM
Subscribed. I started noticing this on mine after the weather warmed up, thought maybe it was just the turbo whistle. I only hear it when another vehicle passes me (going the opposite direction of course), or when driving through a place where there is an echo, if that makes sense. And only notice it at lower speeds. Weird.
That's like playing hockey without a cup!
2005 F350 (RED) Fx4
Crew Cab - Long Box
Edge CTS Monitor
SCT Tuner - GearHead custom tunes
Custom Diesel Coolant Filter
Everything else stock with the exception of what appears to be a 4" Banks exhaust from turbo back..
sgt_forward is offline
post #6 of 8 Old 06-04-2013, 07:01 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Curious to know the issue too!! Good Luck!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #7 of 8 Old 06-05-2013, 03:35 AM Thread Starter
Haven't had a chance to look at it yet. Will let you all know when I figure it out. Thanks for the help.
***MOLON LABE***
W/O CATS
post #8 of 8 Old 06-05-2013, 04:53 PM Thread Starter
Pretty sure I figured it out....had a loose clamp where the CAI meets up with the turbo. Tightened it down and the noise went away.....atleast for now.
And also tightened down the clamp where the EGR gasket is.
***MOLON LABE***
W/O CATS
Tags
engine noise , squeal , turbo whine
