04 6.0L crank but nostart-after ipr replace - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-03-2013, 11:26 AM Thread Starter
Says it all in title. Truck ran and drove just fine other than a random idle sometimes(reason why we replaced the IPR), but after we put it back together it wouldnt start.
I remember it made the injector buzz on the first key on position but now the injectors just are not working(as far as i can tell...im not a diesel mechanic in anyway haha).
As for everything else, fuel pump is turning on, batteries have tons of juice, starter working good.
One odd thing i did notice is that while its turning over the RPM gauge does not move-does this indicate anything?
The only thing i could really point to is air in the fuel system...however i dont see how that would prevent the injectors from turing on.
thanks
nick
2004 F-350 6.0L
The-Dude707 is offline
post #2 of 3 Old 06-03-2013, 11:52 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
No start issue? Look here.
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 3 Old 06-05-2013, 07:28 AM
Sno-Mow's Avatar
Check wire connections to make sure they're hooked up.
If you took off the FCIM check to make sure ground and plugs are FULLY seated.
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
