2003 6.0 no crank - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-02-2013, 10:11 AM Thread Starter
shamrock442's Avatar
2003 6.0 no crank
Have a 03 6.0 no crank, no reverse lights , no back up sensor stuck in 4 low electronic 4 wheel drive. Has new hpop, new ipr , new icp, pulled ficim and PCM and put them both in another 03 that one started and ran fine. Reinstalled in my truck and it fired right up and ran fine. Tightened every thing up took it around the block and it was stuck in 4 low and then kept stalling out and would move 100 feet and stall again nursed it back into my driveway and it stalled again this time no crank. And also both my SCT tuner and my scan gauge 2 power up when pluged into obd2 but say unable to connect. Checked all fuses with fluke all good checked pins on obd2 has power. PCM has power jumped the starter with wire on passenger side and it cranked but no start. Checked all chaff spots nothing totally lost at this point. Any help will be greatly appreciated thanks. Oh and ficim is good.
shamrock442 is offline
post #2 of 4 Old 06-02-2013, 10:57 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Off the top of my head I would check the PCM connection
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #3 of 4 Old 06-02-2013, 01:14 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Check your 5vref at the map sensor. Sounds like a shorting circuit
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #4 of 4 Old 06-02-2013, 05:27 PM Thread Starter
Checked all the PCM connections they are good did pin out readings all have power but I only had a 2005 6.0 pin out I would like to find a 2003 6.0 pin out also was wondering what resistance should be on 12 pin c1282 connector plug should be
Tags
4 wheel drive problems , no crank , no start , reverse lights
