2005 6.0 turbo boost 60+ - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-31-2013, 05:36 PM Thread Starter
I got now a 2005 6.0 powerstroke with check eng light on for turbo underboost condition and overboost condition.While driving normal it will run around 20-30 while accelerating and on a hard acceleration 60+.Now the I cleaned off the egr valve and Iat sensor and condition is the same.Now I'm thinking either the vgt solenoid is bad or may'be the vanes are rusted up.Anyone had similar issues with theirs???
chubacabra is offline
post #2 of 4 Old 05-31-2013, 05:41 PM
Njstroker91's Avatar
Sounds like a serious case of sticky vanes I know when my unison ring was worn out I would get normal boost but under wot it would shoot well over 30 pounds and hold. You have any sort of monitor you can read vgt%
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #3 of 4 Old 06-01-2013, 02:33 PM Thread Starter
I was thinking the same but can the ebp cause this too happen going to clean it this weekend
post #4 of 4 Old 06-01-2013, 03:15 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I sure hope you have ARP studs. If you are pushing that much boost through the heads on TTY head bolts you are going to push a head gasket.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
