deltas are good but losing coolant - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-31-2013, 03:45 AM Thread Starter
i know there is a ton of threads about coolant loss but couldnt find one that helped me. anyway my dads truck is an 07 6.0 and i threw my insight in to chek the deltas and they were only off by 6 and truck has no puking issues when unloaded but we took a trailer up to canada about a 7 hour drive and she started puking. took the cap off didnt seem like there was a ton of pressure. on the way home it overeated one time so we stoped and coolant was only about a half gallon low so we added more and it didnt overheat anymore. last year ford did a headgasket check and said they were good. any tests i could run on it to help me diagnose this? thanks in advance for any help.
03 exsb silver
6.0 powerstroke
4inch straight pipe
diablo programmer
nickname "the turb"
SOLD
96 exlb black
7.3 powerstroke
4inch straight pipe
BDP chip
Full force stage 1's
17* hpop
E-Fuel
Built Trans
nickname "the stroke"
powerstrokesmoke96 is offline
post #2 of 7 Old 05-31-2013, 03:50 AM
T diesel's Avatar
Quoted: 21 Post(s)
Sounds just like my truck.
It was the gaskets.
Maybe start with a test kit....
UView Gas and Diesel Combustion Leak Tester Testing Kit on eBay!
2013 F-250 lariat scsb FX4.
6.2. 3.73 lockers. Rear wheel liners.
Camper package. Pullrite 18K lb Superslide, Line X sprayed bed.
Krown rust protected.
"That which can be asserted without evidence, can be dismissed without evidence"
- Christopher Hitchens
T diesel is offline
post #3 of 7 Old 05-31-2013, 03:52 AM Thread Starter
oh i forgot to add this. i was watching the mirror almost the whole trip. never seen white smoke out the exhaust
03 exsb silver
6.0 powerstroke
4inch straight pipe
diablo programmer
nickname "the turb"
SOLD
96 exlb black
7.3 powerstroke
4inch straight pipe
BDP chip
17* hpop
E-Fuel
Built Trans
post #4 of 7 Old 05-31-2013, 04:09 AM
T diesel's Avatar
Quoted: 21 Post(s)
Same as mine again.
I could beat the living daylights out of my truck unloaded and NEVER puke a drop.
It only puked when I pulled heavy.
T diesel is offline
post #5 of 7 Old 05-31-2013, 04:55 AM Thread Starter
quit scareing me! haha i really hope its not but ive done hg on my truck so ig its not that big of a deal if i gotta do um again.
03 exsb silver
6.0 powerstroke
4inch straight pipe
diablo programmer
nickname "the turb"
SOLD
96 exlb black
7.3 powerstroke
4inch straight pipe
BDP chip
17* hpop
E-Fuel
Built Trans
post #6 of 7 Old 05-31-2013, 05:37 AM
You said it didn't have much pressure when you removed the cap... I would suspect a bad degas cap. After that, tee in a pressure gauge into the degas line and watch the pressure when you are hauling. Quick spikes in pressure = bad gaskets.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #7 of 7 Old 05-31-2013, 06:16 AM Thread Starter
that was my thought too. im gonna make one today after work i think
03 exsb silver
6.0 powerstroke
4inch straight pipe
diablo programmer
nickname "the turb"
SOLD
96 exlb black
7.3 powerstroke
4inch straight pipe
BDP chip
17* hpop
E-Fuel
Built Trans
