water in the fuse box under the dash? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-29-2013, 09:11 AM Thread Starter
BWWilliams's Avatar
hi I've got an 06 6.0 all specs below, and i was just getting into my fuse box under the dash the other day cause i needed the fuse puller for something else. when i pulled the fuse box cover off i noticed that there was a significant amount of water inside the cover. it has been raining quite a bit over here but i don't have any visible leaks anywhere. i cant figure out how the water would get all the way under there and pool in the lid of the fuse box. the fuse box itself looks fine but i did have a glitch the other day when my climate control display didn't light up/operate for a little bit then i turned on the headlights and it came on and then it was fine. any ideas? i searched the forum and found nothing on this matter. thanks for the help.
'06 F250 Lariat 4x4
Ex/cab LB, ARP Studs, 4in turbo back, SCT LW TS box tunes, Ford HG, Egr delete w/new up pipe, Blue spring kit, wicked wheel 2/Stock turbo, Stock injectors
Updated: oil cooler, HPOP fitting, stand pipes, trubo feed/drain lines and all that fun stuff
onboard air system/semi horns
High idle mod
4in rad arm lift
37x13.50R17 toyos
Coming soon: PHP tuned FICM/ ECM tunes, custom front/rear bumpers, custom trac bars
BWWilliams is offline
post #2 of 13 Old 05-29-2013, 04:59 PM Thread Starter
BWWilliams's Avatar
Anybody???????
'06 F250 Lariat 4x4
High idle mod
4in rad arm lift
37x13.50R17 toyos
post #3 of 13 Old 05-29-2013, 06:24 PM
PHYRMN's Avatar
Leaky seal around the windshield, many trucks have had this problem. The water leaking on the fuse box can cause all kinds of electrical problems too.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #4 of 13 Old 05-29-2013, 06:28 PM Thread Starter
BWWilliams's Avatar
Oh really? I guess that makes sense. Is there any way to prove that?
'06 F250 Lariat 4x4
High idle mod
4in rad arm lift
37x13.50R17 toyos
post #5 of 13 Old 05-29-2013, 06:31 PM
ZMANN's Avatar
Quoted: 1470 Post(s)
if you don't have cab lights or a moon roof
what more proof do you need ?
We Miss you Ronnie
ZMANN is offline
post #6 of 13 Old 05-29-2013, 06:37 PM Thread Starter
BWWilliams's Avatar
I need to convince the dealer that they need to fix it under warranty
'06 F250 Lariat 4x4
High idle mod
4in rad arm lift
37x13.50R17 toyos
post #7 of 13 Old 05-29-2013, 06:42 PM
ZMANN's Avatar
it is a common issue and if your not set on trying to get them to replace the fuse box
the windsheild can be resealed at home without removing it
but the proper way is rip it out and re seal it
We Miss you Ronnie
ZMANN is offline
post #8 of 13 Old 05-29-2013, 06:48 PM Thread Starter
BWWilliams's Avatar
Oh I can build motors and pretty much everything else but me and glass don't get along lol
'06 F250 Lariat 4x4
High idle mod
4in rad arm lift
37x13.50R17 toyos
post #9 of 13 Old 05-29-2013, 07:06 PM
rogerallen33's Avatar
I took a windshield out of a monte carlo once with a guitar string and 2 pair of needle nose pliers, and resealed it, im sure their is a easier way now a days this was like 10 years ago,, but I had heard of this happening before water in the fuse box from the windshield leaking
rogerallen33 is offline
post #10 of 13 Old 05-29-2013, 07:13 PM Thread Starter
BWWilliams's Avatar
Ok well I'll see what they say at the dealer then maybe I'll give it a shot
'06 F250 Lariat 4x4
High idle mod
4in rad arm lift
37x13.50R17 toyos
