Oil temp and coolant temps seem high? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-28-2013, 12:43 PM Thread Starter
Just picked up a insight and my coolant is runnin about 204-208 and oil temp is within 8 -10 the whole time cruising at 70. Those temps just seem high to me. Is this normal?
Seand717 is offline
post #2 of 16 Old 05-28-2013, 12:46 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Your coolant does seem to be a little high if your empty. I normally see around 190 unless its hot outside and my driving like a teenager
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 16 Old 05-28-2013, 01:08 PM Thread Starter
Yea I was unloaded. About 90 degrees out today. Have my tuner on looney with full exhaust egr delete, coolant filter with elc coolant if that makes a difference. I wasn't gettin on it at all.
Seand717 is offline
post #4 of 16 Old 05-28-2013, 09:49 PM
Quoted: 8 Post(s)
I would start by testing your coolant... Or better yet upgrading to an elc coolant and change your thermostat
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 16 Old 05-29-2013, 04:14 AM Thread Starter
How do I test it. I have elc coolant it's only been in the truck maybe 2k miles
Seand717 is offline
post #6 of 16 Old 05-29-2013, 04:02 PM
Quoted: 8 Post(s)
You can get testing kits just about anywhere auto parts are sold, but since its that new I would think your coolant is good. Have you checked your fan clutch? Also what year is your truck?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 16 Old 05-29-2013, 04:19 PM Thread Starter
It's a 2005. I went ahead and bought a new thermostat today and more coolant. I did a flush when I did my egr delete and maybe I didn't get it clean enough. So I figured I'd change the stat and replace coolant again.
Seand717 is offline
post #8 of 16 Old 05-29-2013, 04:21 PM Thread Starter
Fan clutch comes on when it gets about 215 I think. I heard it the other day.
Seand717 is offline
post #9 of 16 Old 05-29-2013, 04:32 PM
nolefanreed15's Avatar
I run about 192-198 coolant temps in 85+ temperature.
-2005 F250 6.0, EGR Delete, Oil Cooler Upgrade, ARP Headstuds, 5" MBRP Exhaust, Blue Spring Upgrade, SCT X3 w/ IDP Tunes, 17" MetalMoto's, 35" Toyo Mt's, Retro Solutions 55 watt HID Headlights, Xenon Fogs, 08 Tail Lights
nolefanreed15 is offline
post #10 of 16 Old 05-29-2013, 04:47 PM Thread Starter
Yea that's the temp I've been readin alot of people run at. Hopefully the new thermostat and coolant will do something. Today on way to work I was runnin 65 and ect was 200-207 eot was 8-10 above that
2005 f250
Arp headstuds
Egr delete
4" straight pipe
Sct tuner
8" with 37s
Coolant filter
Elc coolant
Seand717 is offline
