Boost 20-30psi - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-28-2013, 01:18 AM Thread Starter
585Amarillo's Avatar
Boost 20-30psi
OK, so the issue is when I'm on the highway and I'm cruising then get into the pedal it goes to 30psi of boost and its quiet , but when I'm on the street and i punch it it just goes to 20-22 psi and its loud like a raped ape.
so what I'm asking is, is something wrong with my tuning or is this normal?
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #2 of 5 Old 05-28-2013, 02:08 PM Thread Starter
Anyone got the same thing that happens?
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
post #3 of 5 Old 05-28-2013, 03:54 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Normal! When you roll it in in overdrive, the TC is locked or close to it and it builds the boost due to the load. If you are slower and punch it, it downshift, and the TC is nowhere near locked so the truck senses less load on the engine and gives you less boost. It is all in the PCM and sensor parameters.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 5 Old 05-29-2013, 05:19 PM
rogerallen33's Avatar
I can be running 65 to 70 and punch it, and it's not as loud, as if I punched it from like 35 to 40, but it is still loud though, but not as loud,, im straight piped 4 in from turbo all the way to the rear,,,,, how do you like your stacks, I have been thinking about it
early 04 f350 crew cab, long bed
motor built by trucks unlimited, Winston Salem NC to many parts to list
arp head studs
egr delete
blue spring
k&n cold air
4in turbo back straight piped
6in lift, 35x12.5x20 nitto trail grappler, 20 in massi rims
new hpop, updated stand pipes, no stc fitting or dummy plugs to worrie about
sct tuned
rogerallen33 is offline
post #5 of 5 Old 06-01-2013, 03:34 PM Thread Starter
I love them, they wake the dead.
K&N Intake
MBRP 4" Turboback
Zoodad Mod
Ford Updated parts
BPD FICM
ARP Head-studs
Stock Injectors?
EGR Delete
10" Lift
4.56 Gears
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
