Heat & A/C problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-25-2013, 12:40 PM Thread Starter
Heat & A/C problem
I have an 04 6.0L Excursion, last couple of days I took engine apart to replace EGR cooler and Injectors. Once I completed that, the climate control is not working properly. Air only comes out of the defrost even if i select vents, floorboard etc. The back is working just fine, and the air still blows out hot or cold. Any ideas?? thanks for the help.
jtrujilloses is offline
post #2 of 5 Old 05-25-2013, 01:02 PM
sprksonu's Avatar
You either broke a vacuum line or forgot to plug it back in.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 5 Old 05-26-2013, 12:26 PM
spettit379's Avatar
The vacuum pump is on the passenger side wheel well in the engine compartment. It's a small pump with vacuum lines going to the storage can. Make sure it's running and that there are no leaks.
spettit379 is offline
post #4 of 5 Old 06-06-2013, 09:22 AM
any pics of it?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #5 of 5 Old 06-06-2013, 02:07 PM
spettit379's Avatar
pics of vacuum pump
It's got an orange connector on it.
ID:	121666   Click image for larger version
