White Smoke Hard Start 1st time diesel owner - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-23-2013, 04:22 PM Thread Starter
Hey Guys, I'm new to the forums and new to the diesel world. I was recently given my dad's 03 F-350 with the single rear wheel axle and the 6.0. It has 223,000 miles on the odo. The truck has had problems since the day I got it and it has not gotten much better. The truck has been poorly maintained and basically ignored for the past couple of years. The speedo doesnt work and the abs light is on. I think its the rear ABS sensor, so i am just waiting on the part to replace it. The truck has been hard starting and blowing white smoke at startup but it clears up after the truck is warm. When it starts it barely does and starts at very low RPMs and then "winds up" to idling RPMs. It also is running badly at highway speeds. The truck had a leak from an O-ring on the fuel pressure regulator. I replaced the O-ring and replaced the stock spring with the upgraded blue spring. The truck runs a little better but it still is having issues. I also changed the oil, oil filters, fuel filters and cleaned the EGR valve. The truck isn't losing water and the intake looked dry but very dirty. I've got two bottles of Rev-X oil treatment on the way and I'm hoping that clears up my issues. Does anybody have any suggestions before I bring it to a shop and have to spend money that I really don't have right now? And is the truck okay to drive for a few weeks? Thanks in advance, I have learned so much already from you guys by just looking in the forums.
03 F-350 Super Single King Ranch 6.0
Blue Spring Upgrade
Shimano is offline
post #2 of 5 Old 05-23-2013, 04:47 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
White smoke indicates you could be burning coolant... Possibly a EGR failure or head gaskets... Id check your EGR valve first!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 5 Old 05-24-2013, 02:32 AM Thread Starter
I'll do a pressure test today then. Here's a video of this morning's cold start
Blue Spring Upgrade
Shimano is offline
post #4 of 5 Old 05-30-2013, 07:53 PM
southend's Avatar
You need a monitor, without one, you stand to waste alot of money. Sounds like you may have bad batteries and ficm.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #5 of 5 Old 05-30-2013, 08:43 PM
406to907's Avatar
Possible bad batteries but most likely your FICM is going. Mine started having low FICM voltage on start up, white smoke, throwing injector code (guessing the FICM was causing an injector to stick) put rev x in it, white smoke went away and no more injector code but my FICM is still going out, new one should be here tomorrow. Bottom line is you need to get a monitor, edge CTS is the way to go. Without a monitor its basically the blind leading the blind.
06 6.0 CCSB: 4.5" BDS Lift, 18" XD Rims, 35" Trail Grapplers, Custom front bumper, Rigid Flood lights, 5" Diamond Eye Turbo Back Exhaust, Edge CTS Insight, High Idle Mod, FICM Repair.com premium FICM W/Lifetime warranty, ATLAS 40 Tune, Blue Spring Mod, SCT with Custom Tunes, EGR delete, coolant filter kit...
406to907 is offline
