6.0 Smoking at Idle ONLY - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-23-2013, 02:48 PM Thread Starter
Question 6.0 Smoking at Idle ONLY
Currently at 48,000 miles.
Recent Maintenance Done:
Engine Oil Cooler replaced/repaired.
EGR Valve replaced.
Intake Manifold Gasket replaced.
Turbocharger replaced/repaired.
Fuel Filters replaced.
NEW EGR Cooler.
Cranks easy. Drives perfect. Does not overheat.
Once I crank and begin to drive, it does not smoke, but once I hit a redlight and the truck is at idle, it pours out smoke at RANDOM times. Sometimes it smokes, sometimes it doesn't. It happens randomly. I've taken it to 2 Diesel places, and they keep telling me different things. I don't know what is going on and would really like some help from you guys.
The smoke happens at random times and it doesn't matter if the truck is cold, or warmed up.
Opinions? Suggestions?
Thanks.
Leads is offline
post #2 of 8 Old 05-23-2013, 02:52 PM
Korx's Avatar
What color smoke would be my first question.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #3 of 8 Old 05-23-2013, 03:01 PM Thread Starter
White smoke. I didn't really notice a "tint" of blue..
so, I am pretty sure it's pure white.
Leads is offline
post #4 of 8 Old 05-23-2013, 03:05 PM
Korx's Avatar
Does it have a CCV vent? White smoke would usually tell me blow-by or coolant being burnt.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #5 of 8 Old 05-23-2013, 03:11 PM Thread Starter
Once of the diesel places I took it to said that the coolant was being burnt.
They refilled it twice and kept burning.
So, what do you think it could be?
Leads is offline
post #6 of 8 Old 05-23-2013, 03:33 PM
Korx's Avatar
Definitely sounds like the coolant is burning. I'm no expert but to me that could either be a EGR cooler, or head gaskets. Since you said you have a new EGR cooler and EGR Valve, I would lean towards head gaskets.
Best way to be sure would be to tee a pressure gauge into the return line in the degas bottle and monitor it while driving to see if it exceeds 16 PSI.. Any puking?
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #7 of 8 Old 05-23-2013, 03:35 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Yea i would check your EGR valve first, Are you experiencing any white residue around the degas bottle?
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #8 of 8 Old 05-23-2013, 03:53 PM Thread Starter
I was leaning towards head gaskets as well. I'll see what I can do about it..
Thanks for the help Korx, and tkobes.
Leads is offline
