electric trailor plug prob. - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-22-2013, 08:29 PM Thread Starter
teambluemxer's Avatar
so i went to hook to my dump trailer today for the first time in god knows. and no lights or brakes worked. hooked another truck up to it worked perfect. so i figured must be my connection had a little corrosion. installed a new one today no luck. if at all worse. i only get parking lights. no signals no breaks. just parking.... could it be the 7pin harness which goes to the square looking connector on the back. or is there a fuse? its a 2003 6.0
(sold)2000 f-350 w/ helper springs 4x4 crew cab xlt
2003 F-250 XLT ECLB 6.0 4x4
175/75
MTW hybrid
ADII
coolant filter
BPD water pump
SUMP
STUDDED
deleted
New HPOP
6.4 banjo
modded solenoid
tuned by innov. and KEM
teambluemxer is offline
post #2 of 16 Old 05-22-2013, 08:47 PM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Check the #6 fuse, should be 20A.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #3 of 16 Old 05-22-2013, 08:54 PM Thread Starter
under dash or hood?
175/75
MTW hybrid
ADII
coolant filter
BPD water pump
SUMP
STUDDED
deleted
New HPOP
6.4 banjo
modded solenoid
post #4 of 16 Old 05-22-2013, 08:59 PM
jimmyv13's Avatar
Quoted: 46 Post(s)
Under the dash.
jimmyv13 is offline
post #5 of 16 Old 05-23-2013, 06:57 PM Thread Starter
Under the dash.
well ugh the fuse is good i tested it.
175/75
MTW hybrid
ADII
coolant filter
BPD water pump
SUMP
STUDDED
deleted
New HPOP
6.4 banjo
modded solenoid
post #6 of 16 Old 05-24-2013, 07:19 PM Thread Starter
any one? i need help.
175/75
MTW hybrid
ADII
coolant filter
BPD water pump
SUMP
STUDDED
deleted
New HPOP
6.4 banjo
modded solenoid
post #7 of 16 Old 05-26-2013, 06:07 PM
jimmyv13's Avatar
Quoted: 46 Post(s)
Have you verified no signals at both plugs, the 4 flat and 7 round? If so, then work your way back to the fuse panel from the plug wiring. There's got to be a break in the wire somewhere. Seems odd that you lost BOTH sides at the same time...
jimmyv13 is offline
post #8 of 16 Old 05-26-2013, 06:34 PM
jesilvas's Avatar
Quoted: 2 Post(s)
There are various fuses. Check em all.
If good, check power at the first connection you can, and keep working through all them.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 16 Old 05-26-2013, 09:24 PM
Quoted: 10 Post(s)
A quick check is to take a volt meter to the prongs in the connector. The one at about 2 o'clock should be your 12v, and the one at about 7 o'clock should be ground.
Here's a diagram to help you out. The right side will be the same as your outlet.
yinzer is offline
post #10 of 16 Old 05-27-2013, 06:36 PM Thread Starter
turns out the small harness from the square in the back to the actual 7pin had been crushed? idk how it was like that. it was corroded also so i spliced the wires and re did the connections in the small harness but still no go.
175/75
MTW hybrid
ADII
coolant filter
BPD water pump
SUMP
STUDDED
deleted
New HPOP
6.4 banjo
modded solenoid
