No power from dead stop - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-20-2013, 02:43 PM Thread Starter
This problem has been on going for a few months. I had the Turbo, FICM and injectors replaced by Ford. Every since I have only been getting about 7-8 MPG around town and when you push the pedal to the floor it won't get out of its own way. I'm not getting a check engine light. Any help would be great.
sad6.0L is offline
post #2 of 6 Old 05-22-2013, 12:11 PM
Soledad's Avatar
Garage
Could be low fuel pressure, stuck vanes (probably not with a new turbo), thermostat stuck open, clogged EGR, clogged catalytic converter and etc. Are you running any gauges other than what Ford provided? Any boost leaks on the intake side? Any leaks on the exhaust side?
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #3 of 6 Old 05-22-2013, 05:52 PM Thread Starter
Fuel Pressure might be it. I went back over the service tickets and I didn't see where they replace the fuel filters. I ordered a set a couple of days ago. Only have the factory gauges and it doesn't seem to be running hot, not even under a heavy load. I will let you know if that does the trick. No leaks on the Turbo or the exhaust side. I replace the turbo to intercooler boots a few months ago with the turbo. Also had the EGR cleaned.
sad6.0L is offline
post #4 of 6 Old 05-22-2013, 06:41 PM Thread Starter
I found the fuel filter to be pretty plugged. As well as the air filter being ripped. I ordered a new ones from summit and should have them in the morning. It has an AEM Brute Force filter that just came apart when I grabbed it. I have to drive to Salt Lake on Friday with a load so I don't want to get stranded.
sad6.0L is offline
post #5 of 6 Old 05-23-2013, 07:55 AM
Soledad's Avatar
Garage
Yeah, keep us updated. I installed a Fuel Pressure gauge about two weeks ago and found that my fuel pressure is around 45-48psi at idle and can drop below 40psi at WOT. I know my fuel filters are good because I replaced them about 2000 miles ago. And so I suspect my spring is weak and have ordered a blue spring. I'm really really hoping that installing the blue spring will bring up my FP and have a good side effect of providing more power because right now it's kind of a dog off the line.
Soledad is offline
post #6 of 6 Old 05-23-2013, 11:42 PM Thread Starter
Change both filters this morning. Seems to be better. I will know more tomorrow. I have to make a haul to Salt Lake and that will let me know for sure.
sad6.0L is offline
