Black smoke on acceleration, low boost - Ford Powerstroke Diesel Forum
post #1 of 27 Old 05-16-2013, 10:57 AM Thread Starter
pudil45's Avatar
Send a message via MSN to pudil45
06 just started blowing black smoke at acceleration, takes an extra second to get power, and not much boost pressure. Any ideas?
Sent from AutoGuide.com App
2001 F 350 DRW
7.3 Powerstroke
4 inch downpipe to 5 inch mitre cut stacks
Southbend Dynamax clutch
DP Tuner
2006 F-450 6.0
Bone stock
Whelen Justice Wecan
Aluminum 11' bed with folding sides
pudil45 is offline
post #2 of 27 Old 05-16-2013, 11:08 AM Thread Starter
pudil45's Avatar
Turbo sounds fine
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
post #3 of 27 Old 05-16-2013, 11:53 AM
SpeedyDBall's Avatar
Inter cooler boots ripped? Sounds like you have a big boost leak.
'05 6.0 FX4 Lariat DRW:ARP, OEM HG's, Fully Updated, 03 turbo, Warren 155/stock, Pillar Guages(Boost, TFT, EGT, Oil Pressure), Fuel Pressure, Scan Guage 2, 6.4 banjos, Blue spring, MBRP straight pipe, SCT with Nate's tunes, Zoodad, DIY CCV Mod, coolant filter, T6, Final Charge ELC, Strategy VXCF4, Eco tuned FICM
Ficm Repair.com is the $%^&!!!!!!! Great service, and Ed is great to work with. Highly recommended!!!!!!
SpeedyDBall is offline
post #4 of 27 Old 05-16-2013, 02:23 PM
I'm assuming you have your truck stock witg the egr valve, I would say your egr valve is stuck open.
powerstroken00b is offline
post #5 of 27 Old 05-16-2013, 02:26 PM
atvrider93's Avatar
Quoted: 8 Post(s)
Easiest check is intercooler boots and pre-turbo exhaust leak
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #6 of 27 Old 05-16-2013, 03:34 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Only 4 things:
Exhaust leak pre turbo,
Charge air circuit leak,
Stuck vanes (wiring or mechanical), or
PCM issue (ebp, fueling, egr, map).
The first 3 are most likely, the last is possible. It is highly unlikely you have gasket issues or turbo damage.
What are your gauges reading?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 27 Old 05-16-2013, 04:20 PM Thread Starter
pudil45's Avatar
I got on it gettin on the interstate got over 20 lbs but if I romp on it before it kicks in, 10 or less. And yes it's stock. Just had egr cleaned 3-4000 miles ago
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
post #8 of 27 Old 05-16-2013, 04:35 PM
Quoted: 46 Post(s)
Are you running a performance tune of some type? Was it working well before with the same tune? If your vanes are not closing soon enough or your PW is slightly larger, the punch test will show smoke. Same goes for a minor boost or exhaust leak.
Frank
Working for Toys
post #9 of 27 Old 05-16-2013, 04:51 PM Thread Starter
pudil45's Avatar
It's bone stock. Work truck
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
post #10 of 27 Old 05-16-2013, 06:00 PM Thread Starter
pudil45's Avatar
The pipe from the iner cooler to the turbo wobbles a bit
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
