Trans temp and coolant temp different? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-13-2013, 09:33 AM Thread Starter
'03whistler's Avatar
My trans temp shows normal but once it is warmed up the coolant temperature is still a little cool. They are factory gauges so they do not show exact temperatures. I just thought it was odd that they were different.
2003 F350 Lariat Crew Cab Long Box
Sonic Blue
33" Toyo MTs, Zoodad, AFE CAI, 4" straight pipe 5" tip
'03whistler is offline
post #2 of 7 Old 05-13-2013, 01:46 PM
jaysshortbus's Avatar
Those gauges r just for show my trans gauge is the exact same place when its 80 deg. Or 160 deg. Buy yourself a edge cts then u can monitor everything correctly !!
Jay
jaysshortbus is offline
post #3 of 7 Old 05-13-2013, 07:16 PM Thread Starter
That plugs into the obdII port right? So what if I got a sct tuner and wanted to tune it also?
Sonic Blue
post #4 of 7 Old 05-13-2013, 07:45 PM
ZMANN's Avatar
Quoted: 1667 Post(s)
your transmission fluid bypasses the radiator until it hits 180
so don't expect the ECT and trans temp be the same after the truck has been driven for a while when your monitoring
We Miss you Ronnie
ZMANN is offline
post #5 of 7 Old 05-14-2013, 02:25 AM
U leave the gauges plugged in until u want to use the sct then plug gauges right back in thats what I do every time! !!
Jay
post #6 of 7 Old 05-14-2013, 02:53 AM
Write Up: Monitoring the 6.0L PSD. Great reading on temps and what not......
tartfun is offline
post #7 of 7 Old 05-17-2013, 03:07 PM
On my scanguage I have TFT reading, Im assuming thats the tranny temp? Whats the normal transmission temp sopposed to be around?
powerstroken00b is offline
