boosted launch, stripped something - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-12-2013, 04:46 PM Thread Starter
Today I raced my buddy's 350z. I 4x4 boosted launched and beat him but now I have this horrible slipping sound. It sounds like something's stripped. It only does it with both hubs locked in 4x4. I don't think its in the hubs because I locked them individually and no slippage. I'm stumped. Any ideas?
2005 Lariat 6.0
4" TB exhaust to 6" tip
Tuned by the Wildman
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
Blackcloud413 is offline
post #2 of 15 Old 05-12-2013, 04:53 PM
Chatham036's Avatar
Quoted: 133 Post(s)
If you can't locate the issue, I would drain the fluid from the transfer case and check for any shavings
Congrats on whooping up on a 350z!!
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #3 of 15 Old 05-12-2013, 05:14 PM Thread Starter
Thanks man! By about a truck length!
Are these t-cases chain driven?
2005 Lariat 6.0
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
post #4 of 15 Old 05-12-2013, 05:16 PM
c69ss396's Avatar
you won't be able to tell anything by only locking one at a time, you have a open front differential.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 15 Old 05-12-2013, 05:37 PM
04cr450's Avatar
what he said^
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #6 of 15 Old 05-12-2013, 05:37 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Subscribed. Only done 1 boosted launch in fear of something like this happening. I'll be watching so I know what to look for when the sh!t hits the fan
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #7 of 15 Old 05-12-2013, 05:47 PM Thread Starter
Oh ok, The 4x4 on my truck hasn't been used but a handful of times. This is the fourth 4x4 launch its ever seen. I know a guy who abuses the **** out of his and boosts it up to 25psi in 4x4 just for the hell of it and has zero issues. I only built 10 psi before I took off.
I think it's coming from up front, either the driver side hub or the diff. I wouldn't think the diff you crap out that easily.
2005 Lariat 6.0
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
post #8 of 15 Old 05-12-2013, 05:50 PM
Chatham036's Avatar
Quoted: 133 Post(s)
I would be very surprised if it is an issue in the front differential. I have seen the ring and pinion chip one of the teeth but nothing that would cause a consistent "stripping" sound.
I would check the functionality of the hubs, then the t case, then the diff. In this order due to the frequency of failure.
post #9 of 15 Old 05-12-2013, 05:58 PM
c69ss396's Avatar
My guess would be a hub, or a stub shaft. Both are know weak points.
c69ss396 is offline
post #10 of 15 Old 05-12-2013, 06:18 PM Thread Starter
I thought the sound was coming from up front rather than the t-case. I was thinkin driverside hub. I'll pull the hub tomorrow after work and see what's up.
2005 Lariat 6.0
Warren 190's
AD2 sumped
Studs and gaskets
EGR delete
CCV/Zoodad
