Truck randomly died. Turn key and no power anything inside or out. Wont crank - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-10-2013, 10:01 AM Thread Starter
I was out driving my truck yesterday on a dirt road and hit a little series of washboards and immediately my truck died. My gauges are stuck where they were. I show 15 mph on the speedo and everything. Once the truck stopped i put it into park and tried to restart but i had nothing. I turn the key and have no lights come on. I open the doors and no interior domes lights. Nothing happens. it is like my batteries have been disconnected. i have 12.8v per battery or so. Not sure what to check. I ran through the fuses under the hood and under the steering wheel but i didnt find a blown fuse. Checked for continuity with a meter even. At this point i am not sure what to check. The instrument cluster had acted up a little bit before this but the truck never shut down. When i sat act up i mean i would lose my radio, speedo, tach, every gauge and then my power windows. I figured it was just the battery saver relay going out because i had my alternator checked and even replaced it with a new one for a short time with the same issues. The cluster would go out randomly. Now the issue is bad because i have no power anywhere in the truck.
Pete21 is offline
post #2 of 6 Old 05-10-2013, 10:41 AM Thread Starter
My truck is 2005 with 187,000. No real issues up to date. Changes out a couple injectors and then it had a new ficm installed in 09. I can't plug my live wire in to read diagnostic codes due to power. I have zero power inside...under the good light doesn't come on. My power locks don't work... I have checked my connections with my batteries. When I turn the key nothin happens at all. I did blow a serpentine belt about 8 months ago and after that issue I had the intermittent problem with the instrument cluster going out. I just thought the relay was getting weak and I would need to fix it. I have crawled under the truck and check all the wiring that could have possobly been affected by the belt breakage but I found no loose wires or visible chaffing. I have checked the ficm to make sure the harnesses are securely attached there... Honestly not sure where else to check. Is it possible to have a bad relay causing all of these issues
Pete21 is offline
post #3 of 6 Old 05-10-2013, 05:21 PM
Is there anyone you can check thr computer of the truck to see if its still alive? Maybe disconnect all of those wires and the computer and then see what happens. It sounds like it got wet and shorted out. Best of luck.
powerstroken00b is offline
post #4 of 6 Old 05-11-2013, 09:29 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Check your inline fuses too... Coming off the battery on the passenger side. Check power coming into the panel with a multimeter. Should be able to find diagrams on the org
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #5 of 6 Old 05-11-2013, 09:44 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It sounds like the PCM is not getting power. Start line/connector checking power as you move away from the battery. I betting one of your major engine compartment plugs is not making good contact, or you killed both batteries.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 6 Old 05-14-2013, 10:46 PM
I had same issue. Ended up finding the engine control fuse inside the truck was blown. It was the #22 or 23 fuse I can't remember. But it's a 20amp fuse. Check that. Mine blew a few of them that same fuse and I've no clue as to why.
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
