Slow warm up at idle - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-10-2013, 01:37 AM Thread Starter
F350 6.0 powerstroke. I work up northern alberta and have never had a problem with the motor warming up after starting in -40. Now its spring time and warm outside but my truck is having alot of trouble getting warm enough to drive. Even after driving it feels like its legging/ less power and my temp gauge is just above cold. Not at half way like it usually is. I cleaned EGR valve and got some power back but i have no idea why my truck wont warm up. If anyone can give me some advice i would appriciate it bigtime....thanx in advance
ryanprichard is offline
post #2 of 7 Old 05-10-2013, 03:07 AM
6.0f250firstcar's Avatar
It never reaches the middle of the gauge? Sounds like a severe thermostat issue to me?
Ryan
6.0f250firstcar is offline
post #3 of 7 Old 05-11-2013, 08:35 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
The thermostats are cheap enough and easy enough to replace to rule that out. You might want to double check your ect sensor to make sure thats still good because even after driving for a while with a seized thermostat you should be going above just over cold on the gauge
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 7 Old 05-12-2013, 09:55 AM
06Lariat_'s Avatar
Could be the t-stat or the sensor. Also I've learned that the gauges on the dash are useless. If you can it would be a great benefit to get a monitoring device. Edge insight,scan gauge,also there are apps for your smart phone.
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #5 of 7 Old 05-13-2013, 07:49 PM
ps_lane01's Avatar
Quoted: 10 Post(s)
Agreed. All of the gauges on your dash are garbage, get a monitor and look at some actual numbers. It will pay for itself in no time!
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 7 Old 06-03-2013, 07:58 AM
Had similar issue, had to drive for 30 mins for the cab to get warm in +25-35 deg weather. No heat really sucked. Even then the air coming out wasnt hot, just warm. The thermostats are somehow designed to fail open so if it goes bad youre engine is ok. Dealer did computer test and had to rev it for 5 mins to get the ect above 185. $26 later had nice HOT air just in time for spring, a few more mpgs too. Save the old one, it comes with the neck that bolts on, you remove the thermostat from the neck and put that on for flushing the coolant, very handy.
ajfrac is offline
post #7 of 7 Old 04-09-2015, 07:59 PM
on the 6.o powerstroke heating issue. first turn on heater to full, warm engine until thermostat opens let truck come to idle, wait until heater blows cold. with engine running, open degas bottle. if bubbles come out there is air in the system. continue to let engine run until it settles, even fluid comes out of degasbottle, continue this until it stops bubbling, now shut down engine, check level add coolant between min and max close system, all air must be out of the system, also when in park at idle, these diesel will cool off, all of these 6.0 trucks have a high idle wire by the emergency brake supply that wire with 12 volt source and when in park you can high idle to keep the truck warm,
lexington is offline
Tags
cold , gauge , motor , no power cold , slow
