A Little buck or Jerking feeling? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-08-2013, 07:27 PM Thread Starter
I have a 2006 6.0 with 190K. At around 1700 rpm and holding there is a slight bucking feeling and the needle fluctuates +/- 60 or so and I can't think of what it could be. It happens when the engine is cold warm and hot. I thought I wasn't let it idle long enough before I starting driving but it happens all the time. I am sure someone else has had this problem and knows what that deal is. Thank you in advance.
Johnsonmotorworks is offline
post #2 of 2 Old 05-09-2013, 05:44 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
Most often an injector is failing or displaying as failing. Spool stiction most likely, but it could be a coil or wiring issue. Nozzle issues show up as either over-fuel or under fuel issues, but unless it is gross, you need to bench test for that.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
