No crank 2007 f350 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-04-2013, 02:46 PM Thread Starter
No crank 2007 f350
Hi my name is Eddie I have a 2007 f350 with 55k on it. It will not crank but if I jump the starting fuse( the square gray box)under the driver steering wheel. It will fire but it's rough. I do have an oil leak on the high presher system on the motor. Will this not allow the truck to start?
Mx108 is offline
post #2 of 2 Old 05-04-2013, 03:38 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Cranking and starting are 2 different issues. Your cranking issue sounds like a switch or wiring issue.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
