Cruise Not Working - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-04-2013, 10:19 AM Thread Starter
Cruise Not Working
I've read up on a few threads about this issue and still cant seem to find my problem. My cruise doesnt work. Light does not come on when I press the ON button. My horn doesnt work either but I'm not even sure if the horn works right or not becuase the previous owner installed air horns on the truck. Where is the factory horn located? I'd like to rule everything out before I go into the steering column. There are multiple spots of cutting and splicing that have taken place on this truck, so I've been trying to remove anything added on to hopefully clear any electrical problems up. So far, I havent been successful. I did check fuses, but I'm not sure which fuses directly effect the cruise control becuase I only have fuse diagrams I found online. I also did the check procedure but since the light wouldnt come on at all, it obviously didnt work. The truck is an 04 CCSB. Anyone guide me in the right direction? Thanks! ---Jeremy
jdpolzin is offline
