Turbo Issues. PLEASE HELP! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-03-2013, 07:29 AM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
So i welded the exhaust ends of my EGR cooler and re-installed everything. Ever since, I have had weird problems with the turbo. When i start the truck up, it sounds like a intermittant whine, than gradually fades away. When the engine is quickly reved there is a sqreech sound. If i let the truck idle for 5 minutes, the squeeling will come back, change tones, and fade away. I dont think the turbo is operating. When i pull the VGT plug, the sound changed a little bit. I lost my exhaust wooosh sound, it just sounds like a big V8 ideling. Here is what i have checked so far.
-Removed the turbo and cleaned vanes, housing, unisom ring, etc. Verified everything was ok.
-Removed VGT solenoid from a friends truck and installed, same outcome.
-Replaced EBP sensor and cleaned tube.
-Tested MAP sensor
-Tested plug at turbo all the way back to PCM and Ohmd out.
-Tested voltage to hot and pulse signal to ground on VGT plug
-Removed oil supply line from top of turbo, removed FICM relay and bump started to test oil flow, OK
-Replace IC elbows and tightened
-Replaced tube to MAP sensor and intake manifold.
-Removed Turbo SIX TIMES to verify everything was OK
-Triple checked for exhaust leaks
I am ready to shoot myself. Me and my shop full of techs can not figure this out! My trucks been down a week and i probably have 50 hours of labor trying to trouble shoot. the engine idles smooth, the only issues is the turbo. I know the turbo is ok? Any suggestions?
adam214 is offline
post #2 of 11 Old 05-03-2013, 12:16 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
What is your MAP (boost), EBP, and turbo vane positions reading?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 11 Old 05-03-2013, 01:00 PM
Could it be somthing as dumb as the actual electrical plug that attaches to the turbo on the side? What i mean is have you check that plug for corrossion on the inside/missing parts?
powerstroken00b is offline
post #4 of 11 Old 05-03-2013, 02:59 PM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
I dont have a computer that can read all this information. I installed a new MAP sensor and hose, OK. Installed new BPS sensor, OK. Had open wires at the plug to the VGT solenoid. Replace pigtail, OK. Tested VGT solenoid with another, OK. I would think if there was a problem with these sensors, a new sensor would fix the issue, right? I am stumped?
adam214 is offline
post #5 of 11 Old 05-03-2013, 07:29 PM
Quoted: 47 Post(s)
Just because you replaced them, doesn't mean the system is working correctly. The screeching could be a bad bearing, but it could be an up-pipe leak or plumbing bad connection - yes I know you said it was checked x3.
You think the turbo is not working, but when you unplugged the VGT it seems to be at least partially working correctly since the vanes would open and change the exhaust note. You really need to determine which values are not correct. Guessing can be expensive and not very productive, even with the help close by.
Frank
Working for Toys
post #6 of 11 Old 05-03-2013, 07:46 PM Thread Starter
adam214's Avatar
Quoted: 6 Post(s)
We have an autoxray EZscan 6000. I try to monitor these sensors and my scanner says "Lost connection, monitor system shutting down" Every time. Now it wont even try to monitor. Will this scanner not work? Do i have a PCM issue?
adam214 is offline
post #7 of 11 Old 05-03-2013, 07:52 PM
Do you see any trails of black soot around uppipes?
Is the screeching like blowing through a reed or thick grass leaf sideways.
What about a small hole in the weld on the egr cooler air rushing through and screeching?
cfd_shop is offline
post #8 of 11 Old 05-04-2013, 03:30 PM
Quoted: 47 Post(s)
Why it is caging, who knows... However, I have a hunch the unit you are using will not read many of the PIDs you need for your truck. FYI, My 2 year old Pro Scan is very limited when I put it on my truck as well, and it cost more than my DashBoss.
Frank
Working for Toys
post #9 of 11 Old 05-04-2013, 05:17 PM
I just joined the forum tonight and am having issues too. I bought my truck last week and truck was running fine, I decided to install a sinister EGR cooler, Oil cooler, EGR valve, all filters just to be safe. Well that nice jet sound from the exhaust is gone!! If I unplug the VGT no change at all, runs exactly the same. seems like there is very little to no boost. around 2500RPM it falls on its face. no check engine lights and no codes. what gets me is it ran fine before I took it apart!! That bothers me. I will say I have learned a ton from this forum in the past week.
66batrod is offline
post #10 of 11 Old 05-05-2013, 07:14 AM
I would suggest you just read this thread and follow the same diagnostics as prescribed by the op.
Lots of good infoe here
cfd_shop is offline
