Motor has no power issue please help! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-03-2013, 05:44 AM Thread Starter
Exclamation Motor has no power issue please help!
I have a 03 6.0l and when I first start the truck it starts fine but does not have any power to go over 25-30 mph until the motor temp gets to at least 170 degree. What is most likely my issue? Thank an advance for the help.
tarzanmonkeyman is offline
post #2 of 6 Old 05-03-2013, 06:40 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
What are the codes or other parameters; fuel pressure, HPO pressure, FICM voltage, turbo condition (vanes, boost (MAP), EBP)? Does it run rough when you push on the AP when cold? There are so many things it could be, but I am guessing you have a somewhat sticky IPR or stiction issues.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 6 Old 05-06-2013, 07:06 AM Thread Starter
It does not idle rough really when cold. Just will not want to move once you pull out on the road. I don't have any of those readings. I just got a scan gauge tool but haven't really figured it out yet. If there is a reading I get out of it I could put that on here if you could tell me what I need to read.
post #4 of 6 Old 05-07-2013, 10:06 AM
Quoted: 43 Post(s)
Most often it is an injector issue that causes this. Even with one not working it will idle OK, but shows a lack of power. Unfortunately, there are other issues that do the same. You need to check for codes and then ensure you have good ICP readings. The next would be to esure your FICM is good. Have you checked or changed your filters lately with OEM?
If you have done fhat, you should consider getting the fuel pressure checked and a contributionn balance test done.
As an example, my truck starts and seems to run OK, but it has a miss on one cylinder fhat is noticeable on accelleration at about 1400 rpm. However, in my case it still puts 440hp to the wheels. It lacks power to what it should have. On the stock tune it seems to be a real dog. I will probably end up fixing or replacing the bad injector.
Frank
Working for Toys
post #5 of 6 Old 05-07-2013, 06:32 PM Thread Starter
Is there any way for me to check for a bad injector myself? or is that something the dealer had to check? Also as far as filter changes I change my oil filter every 5-6 thousand miles and my fuel filters every other oil change. My FICM is only around 2 years old so in hope that's not the issue because that thing was not cheap. And I also replaced the ICP sensor about a month ago so I hope that is not the issue either.
Also my check engine light is not on so the truck is not giving me any codes on my scanner.
post #6 of 6 Old 05-08-2013, 11:36 AM
Quoted: 43 Post(s)
I posted in the engine problem area on a similar problem. If you want to do it, the best way is with AE -Ford bundle. Manually disconnecting the injectors is possible, but is aPITA and is not as complete. Read up on AE and you will get an idea of how it will help you. Your Ford dealer should be able to give you a good diagnosis with their platform. However, if you want to wrench your own, you need the right tool to make it happen. The AE is very good, especially considering the price.
Frank
Working for Toys
