Help!! 6.0 New Oil Cooler Cover has no threads for the brass valve! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-02-2013, 01:22 PM Thread Starter
I recently purchased a new oem oil cooler cover for my 6.0 because my old one was cracked. Everything Is exactly like the old one but the new one doesn't allow me to transfer over the brass valve due to it not having threads, a recess for the oring to sit in, and a drilled hole. Should I be concerned about not installing this brass valve. It seems like its some sort of a relief valve or maybe a spot to connect a gauge to check the hpop pressure. If anyone knows or could help me would be appreciated. I don't want to install if its something much needed
Name:	Old Housing.jpg
ID:	105881   Click image for larger version
Name:	Old housing with threads no valve.jpg
ID:	105889   Click image for larger version
Name:	New Housing.jpg
ID:	105897   Click image for larger version
Name:	New housing no threads.jpg
ID:	105905   Click image for larger version
Name:	Old on left New right.jpg
PStrokin6.0 is offline
post #2 of 11 Old 05-02-2013, 01:38 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Pictures would be helpful. Take pics of both and post the image code from photobucket.com here after you upload the pics to it.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 11 Old 05-02-2013, 02:57 PM Thread Starter
Hey pics should be up now! any help would be grateful. Nice truck tuscany! i love my 6.0 but i would really love yours!
post #4 of 11 Old 05-02-2013, 03:03 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
That's just the test port. They aren't used for anything. Your all good bud.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 11 Old 05-02-2013, 03:18 PM Thread Starter
Out of curiousity is that port just there to test HPOP pressure for failure?
post #6 of 11 Old 05-02-2013, 04:17 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
No the test port for the hpop is on the hpop.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 11 Old 04-15-2014, 08:24 PM
Tired Marine.
Treynolds08's Avatar
Where did you fine the cover?
Treynolds08 is offline
post #8 of 11 Old 04-15-2014, 09:33 PM
Quoted: 26 Post(s)
From what I can see in your pics, there is no thread there but the oil passage hole is. If this is the case, you are going to have a big oil leak!
Shim is offline
post #9 of 11 Old 04-16-2014, 06:44 PM
Quoted: 8 Post(s)
http://www.mkmcustoms.com/ford2003-2...olercover.aspx
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
post #10 of 11 Old 04-18-2014, 04:39 AM
4506.0's Avatar
The hole isn't there. It's closed up and not tapped.
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
