This cant figure this out! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-02-2013, 05:41 AM Thread Starter
powerstrokecrzy's Avatar
Quoted: 228 Post(s)
03 6.0. Will not start. Cranks but no start. It's not getting fuel to the engine. Has a new pump, tank dropped and all lines blew out. Hfcm took apart and cleaned. Motorcraft filters. The pump is pulling fuel out of the tank just not pushing it to the engine. Did we just get a bad pump? I've checked everything with my scanner and everything looks good
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 13 Old 05-02-2013, 06:07 AM
get helper... take off the main fuel supply at the filter bowl. turn it to on and see what comes out. If you already blew out the line (may want to do it again ?) and no fuel comes out (and you have power at the pump and the pump is running), then you have a bad pump.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 13 Old 05-02-2013, 06:19 AM Thread Starter
Quoted: 228 Post(s)
MikeB
Took the line off the hfcm that goes to the engine and turned it on and nothing comes out.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #4 of 13 Old 05-02-2013, 06:56 AM
Z00KA's Avatar
Send a message via Yahoo to Z00KA
Check the many "no start" threads in the 6.0 Engine area of the forum. Many of them (like mine) point to a bad FICM.
Joe
'04 F350 PSD Crew Cab 4X4
Z00KA is offline
post #5 of 13 Old 05-02-2013, 07:17 AM Thread Starter
Quoted: 228 Post(s)
Ficm voltage is good. No fuel in upper bowl.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #6 of 13 Old 05-02-2013, 07:45 AM
charliebayne's Avatar
Had the same problem with my 2003, ended up being my AC compressor locked up
charliebayne is offline
post #7 of 13 Old 05-02-2013, 07:45 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Sounds like a bad pump to me
Please
You could save the life of a sick child
NYC F-350 is offline
post #8 of 13 Old 05-02-2013, 07:47 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1618 Post(s)
How much fuel is in the tank? I had one of these that basicly vapor locked and had a draw straw issue in the tank. It was below 1/4 tank added 5gallons of fuel and removed the upper filter cap and then got fuel. If that's not it then yah I would agree bad hcfm. Did you get a ford one or aftermarket?
Sent from AutoGuide.com App
toren302 is offline
post #9 of 13 Old 05-02-2013, 09:07 AM Thread Starter
Quoted: 228 Post(s)
It's around 1/4 tank, but before we dipped the tank it was bout 3/4 and was doing the same thing then. it doesn't make sense, the hfcm will get fuel to it but it won't push it to the motor. Yes the line is clear. You can remove the line from the hfcm and pour fuel in the top bowl and it will come out the bottom, plus the line had been blowed out.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #10 of 13 Old 05-02-2013, 10:13 AM
Bump To Pass!!
toren302's Avatar
Sounds like somthin in the hcfm is blocking the fuel from being pumped out. I would start with a new hcfm...and a ford one at that.
toren302 is offline
