LPOP issue? Oil? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-30-2013, 11:12 AM Thread Starter
LPOP issue? Oil?
Okay so for awhile now once my trucks oil temp gets above 175 if I turn the truck off it won't come back on till the oil temp is around 165. When it does come back on its a LONG painful crank and kind of stutters into running. Also the oil gauge on the dash doesn't come up till about 2/3s of the way through the crank. My research has led me to LPOP but I'm not certain. I thought the oil could be the problem because for winter I changed my oil to 5w40 synthetic and possibly once it's warm it could be too thin? Help me out please
Powerstokin is offline
post #2 of 9 Old 04-30-2013, 06:53 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
What brand filter do you have? Do you have oem filter cap? The spring in the lpop which allows only a certain amount of pressure may be worn or clogged with crabby oil. Make sure filter is oem first
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 9 Old 04-30-2013, 06:54 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
It could also be a hpo leak as well if your having a long hot start
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #4 of 9 Old 04-30-2013, 07:43 PM Thread Starter
the filter is OEM replaced less than 5000 miles ago when i put the 5w40 in. cap is OEM as well
post #5 of 9 Old 04-30-2013, 07:45 PM Thread Starter
oh gosh I hope not. i thought it wasn't HPOP because it never dies while driving or anything like that. maybe im wrong?
post #6 of 9 Old 04-30-2013, 08:17 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Well if your lpop is having trouble feeding the correct pressure and volume to the hpop resovoir it may starve the hpop- thus feeding air into the system giving it a long start. If its having trouble starting when its warm then 9/10 times its hpo system related. Its hard to say without some real numbers. If you have a scanner bring up icp desired, icp actual, ipr duty cycle, ficm voltage before during and after cranking. We can get a better chance of diagnosing with some real numbers ya know?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #7 of 9 Old 04-30-2013, 08:20 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
When u shut your truck off with hot oil and a hpo leak, that leak is much easier to find air in the system because the oil is thinner. How come your seeing a maximum of 175 degrees oil temp? Should be around 185 -200 at normal operating. Whats your ect like?
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 9 Old 05-01-2013, 10:16 AM Thread Starter
It's not maximum 175 I'm just saying when it's above that it won't come on
post #9 of 9 Old 05-01-2013, 10:17 AM Thread Starter
I have a scanguage ill try to get those numbers
