Help 2614 2617 no start - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-29-2013, 08:23 PM Thread Starter
Ok I've had problems with my 04 6.0 starting the last couple days. At first wouldn't start at all then I got it started after a lot of cranking and it ran fine. Then next time I started it immediately died and did so a few times until I kept foot on gas for a minute then it would finally idle. Also has a miss fire in cylinder six. Codes for that are injector high injector low and contribution balance. The 2614 and 2617 are for the cam and crank position sensors. Truck doesn't have near the usual power. Is this due to those sensors? Also everything else tested good ficm tested good and icp reads good and ipr. Also hpop and oil pressure are good. Thoughts? Thanks a lot!!!!!!
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #2 of 20 Old 04-29-2013, 09:01 PM
KCCO!!
kells17's Avatar
I threw contribution on #5 cylinder and had to replace that injector. Consider buzz testing injectors, check harness for chaffing. This is what I did to track down my contribution code. As far as crank/cam sensors...you threw these DTC's for excessive cranking. Once you get her fired up again, clear DTC's and they should go away.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 20 Old 04-30-2013, 01:03 AM Thread Starter
So the no start could be because of injector?
Amfw119 is offline
post #4 of 20 Old 04-30-2013, 01:05 AM Thread Starter
Seems to be that when truck gets cold it won't start but while its hot it fires right up
Amfw119 is offline
post #5 of 20 Old 04-30-2013, 01:33 AM
KCCO!!
kells17's Avatar
One bad injector shouldn't keep your truck from starting. When you try and start your truck, does your FICM drop below 45V? Check your batteries as well, may want to get them load tested. If those check out, I would be at par to say stiction. Does she start and run now?
VA Strokers
757 Diesel
kells17 is offline
post #6 of 20 Old 04-30-2013, 03:51 AM Thread Starter
Ficm doesn't drop below 48 volts. She starts after alot of cranking until its warmed up then it fires right up. Should my tach move while cranking? Because it does not. I will get batteries tested ASAP
Amfw119 is offline
post #7 of 20 Old 04-30-2013, 03:52 AM Thread Starter
Had it in scanner at local diesel shop and had injectors tested and that's what they got was injector 6 high and low
Amfw119 is offline
post #8 of 20 Old 04-30-2013, 03:59 AM
KCCO!!
kells17's Avatar
My tach doesn't move either until she fires up. I'm still leaning towards FICM/electrical issue. When she starts and run, does she miss?
VA Strokers
757 Diesel
kells17 is offline
post #9 of 20 Old 04-30-2013, 04:13 AM
KCCO!!
kells17's Avatar
When you say high/low are you reading high circuit/low circuit? If so, this should lead to an electrical/FICM issue. Have a look at this thread:
Cylinder 6 contribution
If you know anyone else with a known good FICM, swap it and see if that works. It also could be a bad harness...
Let us know what you think.
VA Strokers
757 Diesel
kells17 is offline
post #10 of 20 Old 04-30-2013, 04:15 AM Thread Starter
Yeah it's got a miss I just figured that was due to injector 6 sticking. Could that be ficm issue?
Amfw119 is offline
