No start after ARPs and HG - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-29-2013, 07:01 PM Thread Starter
jtaylor75's Avatar
I installed new oem head gaskets and ARP studs on my truck. At my first attempt to start I heard a weird starter noise, like it was low on compression. Come to find out i broke a rocker arm and bent a pushrod on the number 5 cylinder. The truck would start this morning run for a few moments then die out, any attempt to push the throttle and the truck would cough and die. The starter seems to being making normal starting noises again but now the truck wont run at all. I unplugged the ICP sensor and the truck would now run, but then die out again. So i hooked up my AE and this is what i found.
FICM SYNC- No (cranking will not fire)
ICP is the same as ICP desired
IPR is at 15% until cranking then it jumps to 70-80%
FICM is at 47.50v
FICM pwr is at 11v
CKP and CMP sync (no, even though it switches to yes sometimes. It was doing this before i did my head gaskets.)
I took my truck to a local diesel shop before i decided to do the head gaskets myself to help figure out a misfiring problem. He hooked it up to his IDS and tried to run a relative compression test and it kept kicking him out for failing rpm. However his IDS did get a ficm sync during the test. He told me to try to put a CPS in and see if it helps and it didnt.
Fast forward to now. The truck will not fire off at all no matter how long i crank on it. Sometimes when i crank i can see the RPM gauge fall to zero while the motor is still being spun over. I am getting crank and cam position codes like crazy. Is it time for a new crank sensor or is something else wrong? When the truck was running is was pouring out white smoke but when it died it would puff out some black smoke toward then end and it all smelled like fuel.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #2 of 20 Old 04-29-2013, 07:45 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You need a new CKP either that or the connection is loose. Try zip tying it together to hold it in place. Then double check your PCM to main engine harness connection as well as FICM connections. So long as your not getting FICM sync the engine will never start.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 20 Old 04-29-2013, 08:36 PM Thread Starter
jtaylor75's Avatar
Is FICM sync just CMP and CKP signals?
06 CCSB FX4 Lariat
Next:
A fuel system
post #4 of 20 Old 04-29-2013, 08:48 PM
KCCO!!
kells17's Avatar
Crank and cam sensor codes are from excessive cranking with no start. You shouldn't have to replace.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #5 of 20 Old 04-29-2013, 08:55 PM Thread Starter
jtaylor75's Avatar
99% of the time I could agree, but there has to be more with this FICM no sync.
06 CCSB FX4 Lariat
Next:
A fuel system
post #6 of 20 Old 04-29-2013, 09:03 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
FICM sync is the PCM and FICM syncing together. Without CMP and CKP signals the PCM has no idea where the pistons or valves are and will not send the signal to the FICM to allow the injectors to fire. If your not getting FICM sync than you have either an issue with a loose/frayed/broken connection between either your CKP or CMP or both. Without the PCM and FICM syncing the engine will never fire. Also not to scare you but I have heard of instances where the CKP ring gear slips sometimes causing similar issues as well as the cam tone ring breaking a tooth or two and causing similar issues.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 20 Old 04-29-2013, 09:16 PM
KCCO!!
kells17's Avatar
Hmmm.... imma watch this thread closely...
VA Strokers
757 Diesel
kells17 is offline
post #8 of 20 Old 04-29-2013, 10:00 PM
Like a boss!
Laferty's Avatar
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #9 of 20 Old 04-30-2013, 10:50 AM Thread Starter
jtaylor75's Avatar
I've ohmed out the camshaft signal on the PCM connector and it was 853ohms. I decided to replace the cam sensor with a known good one. I've also replace the FICM and PCM with ones out of my brothers truck. Still getting no CMP/CKP sync and no FICM sync. The CKP sensor seems to be working because i am getting steady RPM on the dash and on the AE while cranking. Any more ideas? The truck went from running rough to not running at all.
06 CCSB FX4 Lariat
Next:
A fuel system
post #10 of 20 Old 04-30-2013, 11:12 AM
RedneckYankee's Avatar
Check your wiring harness on driver side mine did the same thing it was shorted wires on the CPS. Where the shielded cable is spliced to the plug connector. The soldered wires were taped and not covered with heat shrink. Never threw a code until it was running and I shook harness. That's when it threw a CPS low code. Good luck with it.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
