no start issue after working on - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-29-2013, 03:59 PM Thread Starter
I was working on my 2003 F250 6.0L cleaning the turbo, egr delete, ICP sensor replace. After I put everything back together all it does is crank and will not start. I check the FICM voltage and got 47v at cranking and tested the ICP and got 2v at cranking which i calculated at about 1500 PSI. Seems like alot? I have to idea what else to check and suggestion would be fantastic.
jajones1988 is offline
post #2 of 3 Old 05-01-2013, 08:17 AM
jtaylor75's Avatar
Did you get it running yet?
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 3 Old 05-02-2013, 05:13 AM
check all your connection, especially the FICM
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
