2006 f350 no start, FICM good, no codes, sync+ ficm sync good, no smoke, whats next? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-28-2013, 08:10 PM Thread Starter
ill try to make this as short as possible
i work at a car dealer and got a good deal on an 06 f350 diesel non-runner.
the car now cranks, but dosent start, no white smoke comes out, rpm rises a little bit when cranking, sync and FICM sync shows as good when cranking.
there seem to be a weird smell after cranking for a couple of times
here is a list of everything done to the car so far:
1.replacement ecu (old one missing, came off a same year model car with same features)
2. replacement FICM (was also missing) tested gives 48v and no problems with scan tool
3.new Camshaft sensor (old had a broken connector and was giving a sync problem)
4. new fuel filter (both replaced)
tested:
-took out injectors and had them tested they where good
-did the key on engine off test from the diagnostic scanner, everything good
-removed ICP sensor and tried to start it same thing.
-did injector test through scanned, again no codes or problem showed up
from what i have read the only thing left is to remove the IPR and check if it has metal shaving?
what else can cause this problem? everything seems good from computer side and there was fuel in the fuel filter so i know the pump is working, i will try to check the IPR tomorow but was wondering if anything else i should check before?
any help would be greatly appreciated!!!
frk203 is offline
post #2 of 7 Old 04-28-2013, 10:41 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
HPO leak....
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 7 Old 04-29-2013, 12:02 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Great resource...
http://www.ford-trucks.com/forums/87...condition.html
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #4 of 7 Old 05-13-2013, 05:23 PM Thread Starter
thanks alot for the help, i did some more diagnostic and ended up replacing the HPOP (got used one) new STC fitting and seals (one of the seals was bad) but im still getting no start with low icp pressure.
when cranking the ipr is at 84.76% the icp is anywhere between 16-25 psi (.26 V) i tried unplugging the icp that didnt work. i was suspecting a bad IPR but i read somewhere that a bad IPR would result in 0 PSI pressure (not sure if its true or not) that same post also said that a bad injector seal would result in low pressure but somewhere around 300psi.
so as of now im lost again, based on what i have read the low (16-25psi) PSI would point to a leaky stc fitting, but i just replaced that and all the seals that comes with it
could it be that the replacement pump i got is bad?!?
frk203 is offline
post #5 of 7 Old 05-13-2013, 05:45 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
IPR is a commanded position, not an actual position. So you need to check it. Apply shop air to the HPO system to see if you have a leak and hopefully find it with a good ear. It may also help you determine if the IPR is bad, the HPOP is bad, a seal/o-ring is leaking or some of your previous work needs adjusting.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 7 Old 06-04-2014, 12:45 PM Thread Starter
thanks for the help guys, turned out to be the replacement HPOP i got originally was bad (it was a used one that was supposedly tested and in working condition) now the car runs good and everything seems well.
thanks again everyone for the help
frk203 is offline
post #7 of 7 Old 06-05-2014, 04:23 AM
Thanks for posting back with your final soloution. Not enough people do.
We never know if any of our suggestions helped unless they report back
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
