no start, no dtc's - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-28-2013, 07:55 AM Thread Starter
powersmoker's Avatar
no start, no dtc's
under heavy acceleration when rolling back out of the throttle truck dies. usually restarts. last time it died wouldn't start again. it had some codes for the egr but its because of my full delete. after it wouldn't start I skanned for codes and even the usual egr codes were gone.
1999.5 ford f250
DIY INTAKE
TS CHIP
TNBB TURBO
4 in straight pipe
6 in lift and 35 at
soon to come
stage ll injectors
powersmoker is offline
post #2 of 9 Old 04-28-2013, 08:03 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1009 Post(s)
Feedback Score: 6 reviews
Do any dash lights come on when it dies?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #3 of 9 Old 04-28-2013, 08:11 AM Thread Starter
I cant recall. what would be the difference if they did or didn't. I am thinking its the crank sensor. because I don't have a tach signal when cranking. are these as prone to going out as the 7.3s
1999.5 ford f250
DIY INTAKE
TS CHIP
TNBB TURBO
4 in straight pipe
6 in lift and 35 at
soon to come
stage ll injectors
post #4 of 9 Old 04-28-2013, 09:00 AM
RIP Cam!
The reason I asked is that my truck used to die on me while driving and then not want to restart every time. I would get the WF light and the glow plug light when it would die. It ended up being a bad FICM to injector harness. As far as the crank position sensor, everything I have read and been told is that they as common of a problem as the 7.3s are. The crank position sensor DTC is P0335, so if you aren't getting that than I wouldn't think that is the problem.
What device are you using to pull codes?
Also, based on your sig, it looks like you have 7.3 mods.
post #5 of 9 Old 04-28-2013, 09:20 AM Thread Starter
I used to have a 7.3 never changed my sig. using a snap-on modis. the reason I thought crank sensor is I have no tach signal while cranking.
post #6 of 9 Old 04-28-2013, 09:26 AM
RIP Cam!
Oh ok.
Hmmmm... can you check ICP and IPR values while cranking?
post #7 of 9 Old 04-28-2013, 09:32 AM Thread Starter
yes but I have to go get my scanner from the shop ten miles away. it has a new ipr in it. it takes a while of cranking to get the oil pressure gauge to come up. the wf light flashes then everything goes dead. no signal to anything on dash
post #8 of 9 Old 04-28-2013, 09:35 AM
RIP Cam!
Interesting. I assume you have pulled all the connections at the PCM, checked and cleaned them, and the replugged them in.
post #9 of 9 Old 04-28-2013, 09:41 AM Thread Starter
that was done when I replaced the irp about 500 miles ago.
