turbo keeps spinning - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-27-2013, 07:04 AM Thread Starter
Gapowerstroke's Avatar
When I shut my truck off you can hear the Turbo still spinning. Its kinda loud making a growling noise. Anyone ever encountered that before?
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #2 of 10 Old 04-27-2013, 11:21 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1815 Post(s)
Feedback Score: 4 reviews
mine still spins when I shut her down, but no growly noise, just whistles on its way.....kinda like a cartoon bomb dropping sound.
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 10 Old 04-27-2013, 11:37 AM Thread Starter
Mine sounds more like bearings grinding. No whistle. Other than that it performs great.
post #4 of 10 Old 04-27-2013, 11:52 AM
Might want to check into that a little further....sounds like you may have a bearing that's starting to go
post #5 of 10 Old 04-27-2013, 11:55 AM Thread Starter
Kind of what I was thinking
post #6 of 10 Old 04-28-2013, 07:44 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
It may be the compressor contacting the housing. If this is the case your bearings are probably a little loose, the wheel may be floating around a little more at shutdown with no oil pressure to center the shaft
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #7 of 10 Old 04-28-2013, 09:56 AM
Good call sinner
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 10 Old 04-28-2013, 07:04 PM
Are you sure it is the turbo? I would not expect a sleeve bearing to grumble.
Could also be the fan clutch spinning down.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #9 of 10 Old 04-28-2013, 09:14 PM
DerwoodF350's Avatar
Mine does the same, has done it for several years and I haven't located it. Other than that it runs great.
2006 Fthreefidy FX4 Lariat, ARP studs, EGR delete, 4" TB BD X-hale exhaust(JUNK), RCD 2.5" level kit w/Bilsteins, Nitto Terra Grapplers, SCT Livewire, Liberator Y pipe, Dieselsites Coolant filter & Delo ELC, Zoodad mod, Swamps HOT FICM, Matts SRL++ & tow tunes
, CCV Mod, CompuStar 2way alarm/remote start
To do list: fluids changed out to synthetic,HID's, .
DerwoodF350 is offline
post #10 of 10 Old 04-28-2013, 09:19 PM
Actually I have had my turbo apart twice to clean and did not observe any signs that the comp wheel is rubbing on the housing.
I never thought about the fan clutch tho... Interesting
