P0278 won't go away!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-26-2013, 07:43 PM Thread Starter
Hey I got a 03 6.0 it's got a p0278 code when I first got the truck it would spit and sputter at 2500 or more rpms I changed injector truck ran great no codes drove it for 30 and instantly I hear it having a slight miss so I scan p0278 was back so I swaped icp senser still same did fuel filters and replaced ficm still ran the same so then I unplugged injector harness then it ran really ****ty so I know the harness is good but then I was reading on the forums of it being a bent pushrod or a lifter so I checks valve train rockers good push rods not bent but I relized whoever did the head studs put cyl#6 pushrods upside down so I put them copper up put it back together truck ran great for 30 then went back to having a slight miss but the p0278 code didn't come back till 3,000 miles later the truck has trouble starting sometimes some times it won't start at all it idles smooth no smoke just sounds like a slight miss took it to 3 different ford dealers and no one can figure it out they just tell me they can't find nothing wrong with it any help would be greatly spprieated thanks
Soflo6.0 is offline
post #2 of 3 Old 04-27-2013, 09:03 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Do u have good fuel pressure/ hpo? Try running some archoil or revx see if it clears it up. What kind of oil do you run?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 3 Old 04-27-2013, 04:01 PM Thread Starter
rotella triple protection and I believe so ford would've said something if I didn't at least I would hope they would have checked that out
Soflo6.0 is offline
