Fooling the dealer..... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-23-2013, 08:53 PM Thread Starter
Ok here it goes.....
I am about to bring my truck in for a oil cooler job which is covered by and extended warranty. And heres my plan....
I want to do a good flush on my own with restore and restore + before it goes in because I don't trust them to do it right or even do it at all before they pull the cooler rather than after. The hitch is after my flush I think I am gonna put Ford Gold back in so they don't hassle me on the warranty. I ultimately want ELC in there after the cooler replacement but dont want to have to do a full flush again right after the new cooler. The question is if the gold is only in for a short time do I have to do a full flush or just a few rinses with water before switching over. Or just go to ELC now?
2006 F-350 FX4 sc/sb 6.0
4" turbo back MBRP no cat
Sinister EGR delete
Sinister coolant filter
SCT tunes by Mike @ Sinister
New oil cooler (5/2013 @ 50k)
Boss Plow
Hi-idle mod
Insight CS
Sound off 1400's
Rigid Duallys
fffowler is offline
post #2 of 11 Old 04-24-2013, 04:21 AM
After your restore and restore plus flush you will be fine. You should be able to just drain out the gold and put some good ELC in there. I dont even think I would do a water rinse.. Just drain and fill with elc.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #3 of 11 Old 04-24-2013, 04:40 AM Thread Starter
Ok cool. No worries about a reaction with any residual ford gold in there left behind?
Sinister EGR delete
Boss Plow
Hi-idle mod
Insight CS
Sound off 1400's
Rigid Duallys
fffowler is offline
post #4 of 11 Old 04-24-2013, 05:52 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
You should be fine! Just take it out when you get back!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 11 Old 04-24-2013, 06:15 AM Thread Starter
Great. Thanks guys
Sinister EGR delete
Boss Plow
Hi-idle mod
Insight CS
Sound off 1400's
Rigid Duallys
fffowler is offline
post #6 of 11 Old 04-24-2013, 08:50 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
There will be a fair bit of residual coolant remaining unless you do some rincing to further dilute or remove it. How much distilled you add to remove it is your call. I doubt the mix would pose any problems, since gold isn't that bad if not abused.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 11 Old 04-24-2013, 09:22 AM
I prob would just drain it 2 times just to be safe.. It will cost alittle extra because you will loose some of the ELC but you should get almost all of the gold out with 2 drains I would think.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #8 of 11 Old 04-24-2013, 01:29 PM
No you will not be fine. ELC and gold do not mix... You have to flush it out like you would normally do with distilled.... Hello 28 gallons of distilled again..
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #9 of 11 Old 04-24-2013, 01:34 PM
05_PSD_Erik's Avatar
I'm with 04cr450. I would flush it over and over with distilled after getting it home just to be sure ALL that gold garbage is gone
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #10 of 11 Old 04-24-2013, 06:01 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
fooling the dealer? We dont care whats in it just not green coolant. We are not nazis!!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
Tags
elc , flush , ford gold , oil cooler
