trucks making weird noise - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-22-2013, 05:57 PM Thread Starter
Question trucks making weird noise
I just recently purchased a 2003 f350 powerstroke. Lucked out and found one with 26k on it. First day driving it, going along at about 50mph when I started giving the truck throttle and started feeling it skipping. Angry I stuffed the gas only to have it happen again. I pulled over and let the truck idle for a few minutes pulled out and had no problems after that, until today. Going up a hill at the same speed (50) gave the truck throttle it down shifted and started skipping again. I've got a warranty on the truck but am trying to prepare myself for what possible major problem I could run into. My luck isn't the greatest...hopefully a easy fix?
kazper413 is offline
post #2 of 20 Old 04-22-2013, 06:01 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
could be couple or easy fixes or couple of not so easy fixes...
congrats on truck they are finicky but good
1. have you hooked a set of gauges on it to check some coltages and temps?
you wanna check and make sure FICM voltage is about 46v at bare-minimum
check the difference in temp between ect(engine coolant temp) and eot (engine oil temp).
sounds like a fuel or HPOP (hi pressure oil pump) or system error a small leak is easy to fix with an air check. a bad pump is not so easy. other more experience will chime in. the warranty should be quite helpfull with low miles.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 20 Old 04-22-2013, 06:04 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
could be fuel filters. there is a coalescer on drivers side fram rail for water and another particle filter in engine bay. were you under 1 qrtr of tank of fuel by any chance>? and any codes? there is a way to get them displayed on dash i just gotta get the paper etc...
Justin,
post #4 of 20 Old 04-22-2013, 06:06 PM Thread Starter
Just the gages one the trucks dash. Everything looked fine...the skipping was almost like hitting the rev limiter
post #5 of 20 Old 04-22-2013, 06:09 PM Thread Starter
No lights on the dash, only lasted a minute or so then ran fine after that...I do live in Massachusetts and its been cold the last couple a nights any connection?
post #6 of 20 Old 04-22-2013, 06:11 PM Thread Starter
Full tank of fuel
post #7 of 20 Old 04-22-2013, 06:15 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
im thinking high pressure oil leak. does it do it randomly or mostly when wot (wide open throttle) your truck needs 500 oil psi to just start theres a way to check but its been along time i'll look real quick.
not sure about cold other then the oil pressure there are some o rings under the valve cover that go bad could be really easy fix you just need to find how to hook air pressure to it and listen for hissing etc...
Justin,
post #8 of 20 Old 04-22-2013, 06:21 PM Thread Starter
It's only happened twice both times under throttle, not full throttle but enough to make it down shift
post #9 of 20 Old 04-22-2013, 06:24 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
then its oil pressure, or fuel pressure do some looking and there are a number of cheap ways to check.
also have you checked your batteries anything over 3 yrs could be low voltage could be related
Justin,
post #10 of 20 Old 04-22-2013, 06:27 PM Thread Starter
Cool thanks for the help...I'll keep updating
Tags
motor , skipping
