Need to know part # for coolant hose - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-22-2013, 05:24 PM Thread Starter
Alright so I went to ford to grab some coolant, just for future use, and came back home to my truck leaking quite a bit of coolant. The hose is one that wraps behind the engine, and was actually pressed against the engine burning a hole through it. I've looked high and low but can't find the right hose.
I've got a 2004 F250 6.0.
It's connected to the Overflow Hose and directly below the reservoir. It's the dashed line in the diagram, with the (__) being the reservoir, and you're looking at it from the driver's side.
(__)
_/-----
The Silver Back Gorilla
SilverBackGorilla is offline
post #2 of 3 Old 04-23-2013, 07:16 AM
PHYRMN's Avatar
Does it look like this?
https://www.dropbox.com/s/ed3vp8w0g4...524120215D.jpg
Part Number: 3C3Z18472BB
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 3 Old 04-23-2013, 06:46 PM
USAFBowman's Avatar
That would be your heater hose. Just so you have the actual name of it
USAFBowman is offline
