P0266 injector? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-22-2013, 01:25 PM Thread Starter
novemberdelta's Avatar
Quoted: 3 Post(s)
P0266 injector?
I started having a rough idle problem on and off a few days ago. No codes then. Today it started cutting out during acceleration. It seemed to clear up after the truck warmed up and just bucked a little bit during idle. I scanned it again tonight and pulled P0266 for #2 cylender contribution test fail. FICM is new, voltage is good, and nothing else out of the ordinary. It seems like that injector is probably bad to me with the current symptoms. I've read a few threads saying to do an oil change and add some rev x (never tried it, but I do run synthetic oil). I'm about 500 miles from a service, so I planned on doing one anyways, but not replacing the injector seems like this would just be a band aid if that's the problem. Any thoughts? Also, I found a diagram that says the number 2 injector is the front on the drivers side, can anybody confirm that?
2015 F-250 XLT
Fisher 8.5' Extreme V Snow Plow
novemberdelta is offline
post #2 of 5 Old 04-23-2013, 03:19 AM Thread Starter
Quoted: 3 Post(s)
Bump for the day. I'm changing the oil and filters tomorrow. I ordered rev x too, just trying to decide to pick up an injector or not.
2015 F-250 XLT
post #3 of 5 Old 09-30-2013, 06:06 PM
843Powerstroke's Avatar
Quoted: 6 Post(s)
Did you ever come to find out what the problem was? I'm having the same issue
*SOLD*1994 Twin Turbo Supra
843Powerstroke is offline
post #4 of 5 Old 10-01-2013, 11:32 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
843powerstroke- you check codes? Whats your symptoms?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #5 of 5 Old 10-06-2013, 06:27 AM Thread Starter
Quoted: 3 Post(s)
It was an injector. I ended up changing them all. Had two go on the other side right after I changed this one.
2015 F-250 XLT
