High Delta - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-22-2013, 10:25 AM Thread Starter
Oilylizard's Avatar
High Delta
Had a 20* Delta (174 ECT, 194 EOT) going home the other day. Oil Cooler is just over a year old. I did a flush with restore about six months ago so I'm betting I fudged my cooler. Also my ECT seems low to me what do you guys think? Stuck thermostat? It was 60 degrees during this day.
2005 F-250 4X4
Harley Davidson Edition #00902
Leveled, Sinister Egr Delete, Studded, Sinister Coolant Filter, Rotella EC1 Coolant, 58v FICM, 6.4 Banjos, Blue Spring, SCT Tuned by Innovative, TSD
and the Wildman, Edge CTS W/ EGT Probe, 4" Turbo back straight pipe, CCV mod, 08 Tails, 08 Pan and filter, 08 Rear Diff Cover, 03 whistler
Oilylizard is offline
post #2 of 5 Old 04-22-2013, 10:31 AM
sprksonu's Avatar
yep put a new motocraft thermostat in then repost temps
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #3 of 5 Old 04-22-2013, 10:49 AM Thread Starter
Oilylizard's Avatar
Will do. I did notice during my coolant flush that it already had a cheapo aftermarket one piece thermostat with housing attached so maybe the motorcraft will correct that.
2005 F-250 4X4
post #4 of 5 Old 04-22-2013, 05:47 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Good luck!! Keep us updated!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 5 Old 04-30-2013, 09:49 AM Thread Starter
Oilylizard's Avatar
Got my t-stat changed and my truck is running in the 190-195 range now, but I'm still getting up to a 17*-18* delta. What ya guys think, go ahead and do the oil cooler or do I have some time still?
2005 F-250 4X4
