Fuel gauge problems - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-21-2013, 05:22 PM Thread Starter
Fuel gauge problems
Over the last three weeks my fuel gauge will drop to empty and the low fuel light will come on. This does not happen at every start up, just once or twice every other day. It happens after I have driven about one mile. The gauge will show normal fuel level at start up, and then will drop to empty. Sometimes it will go back to normal fuel level when driving. The tank has fuel in it. The gauge will just act up for no reason. Where can I start looking to fix this problem?
frankmako is offline
post #2 of 2 Old 04-23-2013, 05:52 PM Thread Starter
it was the sending unit. the sending unit was one bunch of rust. it was not making contact inside the plastic housing at the ground area. i should have cleaned the old unit, but i did not want to take a chance. it was not hard to put in the new one. i drop the drive shaft so i could work at the tank. took off the skid plate and took off one side of the tank straps (drive shaft side). used a jack to support the tank and dropped the tank down on one side a few inches. it was easy to replace the sending unit. took about one hour. i don't see why the price of a sending unit is high.
The Following User Says Thank You to frankmako For This Useful Post:
P3Spiers (07-11-2014)
