2003 6.0l loud squeal comming from turbo area help! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-18-2013, 08:05 PM Thread Starter
Ok just replaced my hpop and was going for a test drive made it to the end of my driveway and heard this crazy squealing. Pulled it in the garage and shut it off. Started it for this video and this is what happend. I found what looks to be an exhuast gasket on top of my trans. Could it be from a leak from there? Or are the bellows shot on my up or y pipe? Turbo about to blow? Any help would be great. Going to start pulling and inspecting things tomorrow.
2003 6.0l turbo squeal - YouTube
03xl350 is offline
post #2 of 4 Old 04-19-2013, 06:47 AM
PHYRMN's Avatar
Did you loosen the u-pipe at the exhaust manifold on both sides before you reattached it to the turbo? If not, I could almost assure you that one of the bellows in the u-pipe are cracked. The u-pipes are a pita to get lined up on the turbo.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 4 Old 04-19-2013, 09:43 AM
If that gasket is a flat metal round piece it goes between the EGR cooler and down pipe to the exhaust pipeing.
As stated improper alignment of the flanges is the biggest culprit and can't be drawn in by the clamp.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 4 Old 04-19-2013, 10:34 AM Thread Starter
The drivers side i removed from the manifold te pass side i got to the two bolts up by the egr and removed it from there. Im pretty sure thats where the gasket came from i pull the turbo tonight check the bellows and make sure everything is lined up properly and set in place.
03xl350 is offline
