Leaking EGR Cooler=decision time - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-16-2013, 11:12 AM Thread Starter
philbio2k's Avatar
My situation: I have a 2005 F-350 Lariat DRW 6.0L 91k miles stock except straight piped exhaust, now it has a leaking EGR cooler, gummy EGR valve, and more than likely a clogged oil cooler. I have read through several threads and understand my options for the most part (upgrade or delete EGR cooler, replace oil cooler).
The solution I am leaning towards: Delete EGR cooler, use SCT tuner to prevent CEL, and replace oil cooler with stock part, and get an Edge Insight monitoring system to monitor EOT & ECT (BTW I am assuming these acronyms stand for Engine Oil Temperature and Engine Coolant Temperature respectively) and while we are on acronyms what does ELC mean when referring to coolant (I was thinking some where I saw that it was suggested to get regular coolant out of vehicle and use ELC)?
The only thing I am wondering about is if I can use both the tuner and monitoring system simultaneously. Any thoughts and opinions or advice would be greatly appreciated.
philbio2k is offline
post #2 of 6 Old 04-17-2013, 09:55 AM
You are correct on the acronyms. ELC = extended life coolant. Also be sure is is Cat EC-1 rated.
Yes you can run the SCT and Insight together (sort of). You will load tunes with the SCT through the OBD-2 connector and then disconnect the tuner. Then the Insight plugs into the OBD-2 port to monitor the vitals. (I am assuming when you say Insight it is the version that does not "tune" the engine - very bad to "stack" tuners)
I run SCT tunes and have an Insight installed.
BTW, you sould get a coolant filter installed.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 6 Old 04-17-2013, 11:59 AM Thread Starter
philbio2k's Avatar
Thanks Mike for clearing up the ELC acronym and yes you are correct on the last thing I plug into OBDII being only a monitoring system and no tuning capabilities. I saw a video on installing the Edge Insight CTS and they install a temp probe for the exhaust gas temperature and I don't think I am ready to go to that far just yet so since you have an insight can you use it to monitor the EOT and ECT without adding any probes? Also thanks for the coolant filter suggestion.
Phil
post #4 of 6 Old 04-17-2013, 03:00 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
I run the new SCT livewire TS which is a tuner and monitor in one unit. Most of the site sponsors have deals on them with custom tunes.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #5 of 6 Old 04-17-2013, 04:45 PM
jmeaby's Avatar
Quoted: 16 Post(s)
I think u need to do a certain flush before switching coolants if I remember right. I'm sure someone will correct me. Sct is awsome I'm only using canned tunes till the truck gets studs and I'm getting the edge CS to monitor. And I'm gonna expand.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #6 of 6 Old 04-17-2013, 07:03 PM
Yo asked whether the CTS cam monitor EOT and ECT righ tout of the box. Yes it can. If you want EGT or fuel pressure you have to add on, but the basics already monitored by the PCM can be read with the CTS.
MikeB
PSDMikeB is offline
Tags
egr cooler , egr delete
