No fuel to upper bowl, no start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-15-2013, 06:16 AM Thread Starter
powerstrokecrzy's Avatar
Quoted: 265 Post(s)
alright, got one for ya'll. My dads truck won't crank. No fuel to upper bowl. new filters, new pump, dropped tank, blew all lines out still nothing. getting fuel to the hfcm. even took the hfcm off and apart and cleaned it out, it was pretty nasty inside. when he bought filters i told him to make sure he got fram or motorcraft, but wasn't there to see the box and he's hard headed and thinks a brand of filter isn't gonna matter. Could this be a filter problem. think i'm gonna take the filter out mine and swap it in there and see what happens. we're at our wits end here. Just don't understand why the fuel isn't getting to the motor.
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 6 Old 04-15-2013, 06:52 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
It wont crank or wont start? Get motorcraft filters just to be sure thats not the issue. Did u check your fuel pump relay, fuses, hfcm relay/fuse? Do you know that your getting fuel to the hfcm? Make sure your getting voltage to the pump.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #3 of 6 Old 04-15-2013, 07:14 AM Thread Starter
Quoted: 265 Post(s)
Yes it is getting fuel to the hfcm, no doubt. It's pulling it from the tank just not past that point. It turns over, just won't fire
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #4 of 6 Old 04-15-2013, 07:24 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Can u put a gauge on the fuel bowl to measure pressure? - Im guessing you tried cranking with the fuel bowl cap off? Make sure that primary filter IS motorcraft and installed correctly. If your water seperator was real gunked up full of sand or debri or rust. Your hfcm might be toast.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #5 of 6 Old 04-15-2013, 07:52 AM Thread Starter
Quoted: 265 Post(s)
He doesn't have a gauge, I could take the one off my truck if I have to. But seems pointless tho cause there is no fuel in the upper bowl. Take cap off and it's bone dry, try cranking with cap off and nothing makes it up there. You can hear the pump run. The hfcm was pretty nasty inside, rust and slime, alot of it. What's in there that can go bad. All I seen was the fuel heater and passages for the fuel to flow? Keep the ideas coming guys, really appreciate it.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #6 of 6 Old 04-15-2013, 10:20 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Theres nothing in the fuel bowl that will cause it to get plugged up, going to the bowl. The fuel return line and spring is a different topic...
I have heard of ppl taking carb cleaner and coating the filter area and WIF manifold and then blowing it off very good with compressed air...
Other then that.. Hopefully someone else will pitch in
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
