Ect and eot temps after head studs and new oil cooler - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-13-2013, 06:41 AM Thread Starter
I just recently got my truck back from getting arp studs and I have noticed that my ect and eot seem high. On average driving I see an eot of 192-196 and an ect anywhere from 188-198 most of the time the deltas are only about 3-4 degrees apart. I was just wondering if anyone else thought this seemed high?
My truck is a 2006 f350 regular cab 4x4. The mods are rcd egr delete, sinsister coolant filter, newer hpop, new oil cooler, arps, ford oem head gaskets, blue spring update, stc fitting update, 4inch diamond eye turbo back strait pipe, and sct livewire tuned by Matt at Gearheads
kypowerstroke21 is offline
post #2 of 10 Old 04-14-2013, 02:06 AM
For around here that is a good delta. Depending on your ambient temps that 188* indicates a stuck open thermostat. You should never be below 190 deg. unless it is really cold out.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 10 Old 04-14-2013, 03:08 AM
PowerstrokeSoldier's Avatar
Those numbers look perfect....don't worry about it.
2004 F250 FX4, 6-speed manual, crew cab , SB, all stock!
PowerstrokeSoldier is offline
post #4 of 10 Old 04-15-2013, 09:10 AM Thread Starter
Ok thanks I appreciate it. At what tempature should I start to be concerned ?
post #5 of 10 Old 04-15-2013, 10:07 AM
Snake's Avatar
Quoted: 46 Post(s)
Agreed
The 6.0 defuels when oil temps reach 253*, but if you're not towing or driving in stop and go traffic, I'd pay attention if oil temps went past 220*. Coolant temp should be around the same if the oil cooler is healthy.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 10 Old 04-15-2013, 01:09 PM
Originally Posted by Snake View Post
Agreed
Can you define "defuels" for me ?
lojoman16 is offline
post #7 of 10 Old 04-15-2013, 01:20 PM
Term3's Avatar
PCM commands less than normal fuel injected, which makes less power, less power means less heat produced, less heat produced means cooler coolant and oil temperatures.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 10 Old 04-15-2013, 01:20 PM
05_PSD_Erik's Avatar
If the truck sees the temps getting to high, it will defuel, literally cut fuel back in order to reduce the stress on the engine and help it get back to cooler temps.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #9 of 10 Old 04-15-2013, 04:12 PM
Thank you guys.
post #10 of 10 Old 04-17-2013, 06:16 PM
sorry to hijack a thread here but my temp is on average 178* highest its ever been since i bought my truck is 186*
lrgnugs is offline
