03 6.0 with multiple issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-11-2013, 01:39 PM Thread Starter
I have an 03 F250 6.0 that I just picked up with 140K miles. It has multiple issues unfortunately (what a shocker).
1. She smokes a good amount of blue when I cold start it. It seems to cut out lightly on acceleration and does it worse the slower I accelerate. Also kicks and bucks when accelerating in overdrive, I guess the best way to describe it is if any of you have had a coil pack go out on a 5.4 and how that kicks and bucks in overdrive. Again, its worse the slower I accelerate.
2. After sitting anymore than an hour, the power locks won't work.
3. The power mirrors won't adjust outward, I think it could be the switch.
4. The "miles until empty" is way off, maybe it needs to be recalibrated?
5. Number 115 fuse (trailer tow battery charge) which is supposed to be a 20amp was blown. It had a 30amp in its place which was blown, and with the truck running I replaced it with a 30amp and it blew immediately. That may have been my idiot fault for installing it while running?
6. The radio sometimes stays on after I shut the truck off and open the door.
I believe thats about it. Here are some details on the extras on the truck, it has a newer BOSS plow (lots of wiring), a trailer brake controller that I had to unplug because it was making a ticking noise and blinking constantly. It also has extra back up lights and an orange beacon on top of the Cab rack. I have a feeling some of these extras are whats killing my electrical situations. It also has a brand new 135amp alternator.
Sorry for so much to ask, but I would love any help I can get! Thanks!
Thefarm0913 is offline
post #2 of 3 Old 04-11-2013, 02:55 PM
PHYRMN's Avatar
1. Check FICM Voltage
2. ???
3. Most likely the switch
4. Lie-o-meters are rarely accurate
5. Check all aftermarket trailer hitch/plow wiring.
6. Normal, system will keep radio on after key is off for 10 minutes, unless a door is opened sooner.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 3 Old 04-14-2013, 08:38 AM Thread Starter
2. ???
I removed every bit of aftermarket wiring I could find and am still having every problem. The radio stays on even after the door is opened. I have yet to check FICM voltage though
