Help Before I have to call tow truck - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-11-2013, 01:31 PM Thread Starter
Ok basic's 2006 F350 auto.. Only aftermarket is coolant filter and 58v ficm. Running livewire TS with canned tune.
Was doing my flush prior to getting egr delete done. Pulled stat and was running cardboard on rad to keep at temp. ( All temps were normal on TS an Dash) Was in tow mode to keep RPM up. Went back to reg mode and about 3 minutes later truck shut off doing 50.
Now my on board systems says..
Engine data sensor error, Transmission data sensor error.
Truck will NOT turn over and the cel is on.
We have tried to set back to stock but get a error on TS, Tried to see what dtc codes were on TS and get a error on TS, hit clear codes says it does but still nothing.
Just had bat's checked all at 900+ cca. going out now to clean an dry as many connections as i can get to and re install bats.
Any help or info would be awesome. OHH i also get a TBC failure on my indash monitor
Adam
2006 CC SB 4x4 Amarillo Addition
Pro-comp Lift
Rear airbags cab controls
Airaid
Livewire TS with Vivians Loony
Egr Delete
58v Ficm
Blue Spring upgrade
Stroke_My_Amarillo is offline
post #2 of 11 Old 04-11-2013, 01:51 PM
Glueballs's Avatar
Truck will NOT turn over and the cel is on. (No Crank period or no start? Injector Buzz?)
Any help or info would be awesome. OHH i also get a TBC failure on my indash monitor (This can be caused by the Brake Pressure switch or wiring)
Once you have the batteries in let us know the answers to the above maybe we can narrow it down.
Greg
"You are not thinking. You are merely being logical."
Niels Bohr
06 F350 Amarillo CCSB - MODS - Bulletproof 6phase FICM 58V, Odyssey 65-PC1750, SCT iTSX Tuned, EGR delete, 4" with Cat and Muffler - To be installed - Bulletproof Oil Cooler, Regulated Return w/ fuel bowl delete and FASS.
Glueballs is offline
post #3 of 11 Old 04-11-2013, 01:57 PM Thread Starter
same nothing, can hear buzz nut no crank
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
post #4 of 11 Old 04-11-2013, 02:12 PM
Glueballs's Avatar
Have you tried to start in Neutral? Does the starter click? Do you have a code reader other than the Livewire? What is the voltage KOEO and KOEC
Greg
Niels Bohr
post #5 of 11 Old 04-11-2013, 02:30 PM Thread Starter
just got off phone with STC they think its the pcm fuse under hood, will see if i can find it and check it
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
post #6 of 11 Old 04-11-2013, 02:40 PM
Glueballs's Avatar
Should be located next to driverside battery. I know for sure there is a relay may be a fuse as well. Other thing to try is unplug the clutch on the fan.
Greg
Niels Bohr
post #7 of 11 Old 04-11-2013, 02:46 PM Thread Starter
ok will go try that
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
post #8 of 11 Old 04-11-2013, 03:20 PM
Glueballs's Avatar
Sorry my reply was kind of confusing. Re-read it now. Just to clarify. PCM is located by driverside battery on the fender side. Relay 302 is for the PCM it is located in the fuse block under dash. You can also check 30(15A for starter relay) 113(30A for Starter) and 307 (Relay for starter.) The only thing that makes me wonder is I thought the FICM was on the same circuit and you said you have injector buzz. Not near my truck and only have the fuse numbers on my phone. Don't have my other info.
Greg
Niels Bohr
post #9 of 11 Old 04-11-2013, 04:38 PM Thread Starter
Nothing i tried worked iy left on a cummins powered truck to the shop will post what the problem was incase someone else has it
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
post #10 of 11 Old 04-12-2013, 04:32 PM Thread Starter
Ok truck is at the shop, Seems a wire on the EGR plug shorted out which killed power to a few other things, Unplugged it and fired up. So since they are doing the delete it wont matter, should have only cost me 4 fuses and about 30 minutes
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
