Truck Hesitates when under Load - Ford Powerstroke Diesel Forum
post #1 of 22 Old 04-11-2013, 04:17 AM Thread Starter
Hey guys, new to the forum. I have an 06 F350 KR with 83K on the odometer. No mods or programmer, all the factory services have been performed. Took the truck in to the Dealer a month ago and was having issues with a leak, and some Hesitation that had developed.
The Hesitation is mainly when I either get into the throttle from a start, and its seems to stutter. It also happens when I am on the Highway 70-75 Mph, and I am approaching a hill, the truck again stutters, and hesitates.
I told the dealer at the time, it seems to be "hunting" or starving for fuel.
So they found the Fuel Pressure Regulator was leaking fuel, so they replaced the gasket (O-Ring).
Got the truck back seemed ok, yet then another leak - this time the Fuel Filter Housing.
Back to the Dealer and told them the hesitation was back. They fixed the Fuel Filter, and stated they saw a code for low fuel level. I asked did they mean Fuel Pressure, and they said no, Fuel Level in the Tank. At the time I also told them of the Ford Blue Spring upgrade, yet that when in one ear and out the other.
Well, Truck is doing it again, and I do not have a heavy foot. Its just very annoying to be driving along and it is probably starving for fuel.
I used to work on Diesels in the Army mainly 2 stoke Detroit Diesels and to me it seems like the blue spring upgrade is worth a shot.
I just want to see if anyone has had similar issues, and can either confirm or deny that the blue spring mod is a fix, or I may have another issue at hand.
That being said, I will do the work myself this time.
Any help is appreciated.
drbelleville is offline
post #2 of 22 Old 04-12-2013, 04:43 PM
southend's Avatar
I would highly recommend checking fuel pressure before you keep blowing money. 12x1.5mm oring adapter here.....
Read up on the sticky for monitoring and do yourself a huge favor and get a monitor on your truck. The blue spring update is not a guarantee to fix your current problem, but a major step in the right direction to prevent future problems. It could be a bad fuel pump, clogged suction tube, clogged fuel filters, cracked intake tube, suction foot check valve fell out, and/or sounds somewhat like a bad injector. Has this occurred with the fuel level around 1/4 tank? Are you running motorcraft or racor filters and a good quality oil?
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 22 Old 04-14-2013, 03:23 PM Thread Starter
Thanks for the help and insight, I was going to purchase a monitor off the bat, yet all the work performed recently ate into that budget.
I am running stock Motorcraft filters and 15w40 as provided at the Ford Dealer( they have done all the services so far). And the issue has also happened when fully tanked up.
With all that being said, is there a monitor that offers plug and play right out of the box of Fuel and Oil pressure? I was looking at the Banks iQ 2.0, yet I think that ship has sailed.
post #4 of 22 Old 04-14-2013, 05:34 PM
Glueballs's Avatar
If you have an android or iOS device I would recommend getting the SCT iTSX/TSX($450-475). If you don't and are not planning on tuning your truck I would go with a Edge insight CS($300-450) or CTS($400-600). Only thing the Edges allow you to monitor EGT's with an expandable probe while the SCT does not. I have gauges for mine anyway so it didn't matter to me.
Greg
"You are not thinking. You are merely being logical."
Niels Bohr
06 F350 Amarillo CCSB - MODS - Bulletproof 6phase FICM 58V, Odyssey 65-PC1750, SCT iTSX Tuned, EGR delete, 4" with Cat and Muffler - To be installed - Bulletproof Oil Cooler, Regulated Return w/ fuel bowl delete and FASS.
Glueballs is offline
post #5 of 22 Old 04-14-2013, 05:45 PM
southend's Avatar
If funds are tight, you can get a scanguage II. $160 at autozone
southend is offline
post #6 of 22 Old 04-15-2013, 07:05 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
I dont believe there is a monitor out there with a plug and play for fuel pressure without and external input, most all of the monitors mentioned above will monitor oil pressure though, correct?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #7 of 22 Old 04-15-2013, 08:08 AM Thread Starter
Thanks guys,
I will look into the scangauge from Autozone.
I can run my own transducer and get that setup for Fuel-Pressure.
As an update,
Got in the truck this morning, and all was well.
At work had to head out and run to a different facility, and would not start. Turned the key off, pulled it. Put the key back in, went to start and after a bit of turning started - whew. Then headed out, and noticed a bit of a rougher idle with the A/C on at the light. Kept on about my drive, came to a light, took my turn, drove on, and at about 25mph - No Drive, coasted a bit checked that the shifter was in D (which it was), then had drive again.
After parking and going about my buisness, got back in the truck, and started it, although took a little longer than in the past.
post #8 of 22 Old 04-18-2013, 08:18 AM Thread Starter
Added the ScangaugeII, now I am going to get my fuel Pressure Gauge setup next.
post #9 of 22 Old 04-18-2013, 08:35 AM
The Maddawg
maddawg89's Avatar
Quoted: 304 Post(s)
Feedback Score: 3 reviews
How do you like the SGII?
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #10 of 22 Old 04-18-2013, 08:38 AM Thread Starter
Just installed it, but sofar I love it. Even for the peace of mind, and the few parameters you can monitor without spending much money is awesome.
Got it at Autozone with Military discount for 130 out the door.
