Please help. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-11-2013, 04:59 AM Thread Starter
loganjj27's Avatar
Please help.
I've got a 2004 6.0 in my yard blowing coolant out of exhaust. I have oil cooler and egr delete on hand but the degas bottle cap smell like gun powder (to me). Would i get and accurate gaskets reading in the condition its in now with a gauge? Or could the smell just be part of egr or oil cooler issue?
Logan Johnston
Sales Associate
Rudy's Diesel Performance
1404 Christian Ave.
Durham, NC, 27705
loganjj27 is offline
post #2 of 6 Old 04-11-2013, 05:14 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Blowing coolant out the exhaust is the surest sign of a damaged EGR cooler, most often caused by heat stress from a clogged oil cooler. If you had a monitor on, you would have probably seen the ECT/EOT delta very high, but not always. FIx it before it cost you a head removal.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 6 Old 04-11-2013, 10:27 AM Thread Starter
loganjj27's Avatar
I agree but i would like to know ignore the gaskets are blown before i tear down for egr delete so i can do it all now if they are
Logan Johnston
Sales Associate
1404 Christian Ave.
Durham, NC, 27705
post #4 of 6 Old 04-11-2013, 11:05 AM
Glueballs's Avatar
I checked my truck using a stopper with tubing installed in the degass bottle. Make sure pressure is off system(Critical). Remove Cap and install the stopper with the tube. Place the end of the tube in a bottle of water bigger the better. Start the engine. If you have bubbles you have a leak. Reach in and unplug the VGT and see if the bubble reduce/stop if they do it is most likely just your EGR Cooler. if not you likely also have a head gasket leak. Plug the VGT back in and see if the bubbles increase/start again. Remember to be extremly careful around a running engine. If you have someone to rev the engine a bit before you unplug the turbo it helps see a bigger differance. If no change is seen you likely only have a head gasket leak. But that doesn't lead to much coolant in the exhaust just white smoke.
Hope that helps
Greg
"You are not thinking. You are merely being logical."
Niels Bohr
06 F350 Amarillo CCSB - MODS - Bulletproof 6phase FICM 58V, Odyssey 65-PC1750, SCT iTSX Tuned, EGR delete, 4" with Cat and Muffler - To be installed - Bulletproof Oil Cooler, Regulated Return w/ fuel bowl delete and FASS.
Glueballs is offline
post #5 of 6 Old 04-11-2013, 11:22 AM
Hope that helps
I'm kinda following along here. Do you mean a sink stopper?
To the OP, you need to figure this out ASAP, coolant in the exhaust (regardless of why) means it's in the cylinder, which can hydro-lock the motor and make a HUGE mess of things.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 6 Old 04-11-2013, 11:46 AM
Glueballs's Avatar
No Labratory kind. Like you use in beakers. . I don't rember the size but is was around 1" 1/2 I think. I used tyvek tubing but anyplace that has the stoppers should have hose. Should only be 15-20 bucks or so for everything max.
EDIT: I think the stopper was a #8 but you need to verify and it was tygon tubing I used but any will work. You can buy barbs to put in the stopper or just pass the tubing right through.
Greg
Niels Bohr
