6.0 No Start - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-10-2013, 03:55 PM Thread Starter
Quoted: 2 Post(s)
6.0 No Start
Hey Folks. Always been a great help here. The No Start sticky’s are great, I'm just hoping to get to my problem a bit faster, so thanks in advance for the patience responses. 04 6.0 with 155k. No slouch to mechanics and spent dozens of hours under the hood on this one since 2005.
Wife called for rescue after the Excursion just died and coasted of the road.
Battery's awesome, engine turns over fine/normal, just won't fire...not even a hint. Cold engine start has been great all winter, so I don't suspect GP's. Been running fine for along time.
Already rebuilt the FICM and its putting out 56.6v at both key-on-engine-off and at Start/crank.
New EGR last year (but didn't need it).
Manifold cleaning last year, but no indication of power loss.
Edge Juice/Attitude pulls only a P0275 contribution code for #5, but been getting that one off and on an off for years.
3/4 tank of fuel (duh) and no reason to suspect fuel quality at this point...unless water.
Thats about as far as I am on the sticky.
More direct suggestions?
Thanks for help folks!
Mywifes6.0 is offline
post #2 of 14 Old 04-10-2013, 04:18 PM
rdaffin's Avatar
What is your hpop pressure? I think it has to be around 500 psi to start. Maybe a ICP problem. Sorry not much help but a place to start.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #3 of 14 Old 04-10-2013, 04:27 PM Thread Starter
Quoted: 2 Post(s)
Always a help rdaffin! Thanks! Hpop must be the pressure in the rail...??? My Juice does not give me that so it would be a manual check. Whats the proceedure?
post #4 of 14 Old 04-10-2013, 04:31 PM
PHYRMN's Avatar
Get a scanguage or torque app and see what the IPR and ICP readings are. You can also disconnect the ICP and see if thats the failure, ECM will default too 500 psi and if thats the failure the truck will start.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 14 Old 04-10-2013, 04:37 PM
rdaffin's Avatar
No manual test that I know of. The ICP sensor is on the passenger valve cover towards the front.
rdaffin is offline
post #6 of 14 Old 04-10-2013, 04:44 PM Thread Starter
Quoted: 2 Post(s)
Thanks guys...I'll give the ICP a test tonight after work.
PHYRMN.....which of these "torque app" are availabile to download for a laptop? Probably need OBT2 cable too, yes?
post #7 of 14 Old 04-10-2013, 04:53 PM
rdaffin's Avatar
Under the "monitoring your 6.0 " there is a voltage reading in the first post for the ICP. Should be at .82 at idle and cranking . .2 key on engine off.
rdaffin is offline
post #8 of 14 Old 04-10-2013, 04:56 PM
PHYRMN's Avatar
Torque app works great on my tablet, you just need a cheap ebay obdII bluetooth module. A scanguage is gonna cost upwards to 160.00. One of these is a must have to monitor the engine senors.
PHYRMN is offline
post #9 of 14 Old 04-11-2013, 09:21 PM Thread Starter
Quoted: 2 Post(s)
Ok guys. Made some time tonight. Checked all the fuses and relays…all good. Swapped the #302 and #304 relays…no change. Reset the fuel cut off switch....didn't seem to be tripped. Unplugged the ICP..no difference. Checked the water drain, only got a very small amount of water. Changed both fuel filters. Both pretty clean and no contaminants observed.
Oil pressure seems to build pressure after about 15 seconds of cranking. The gauge spikes to normal for a moment, then drops back off.
Need to check the refill on the upper fuel filter tomorrow, but fuel pump is running like normal, so I expect that will be fine.
The general rule is “When there’s no obvious cause, the simplest solution is the solution.” Given the Excursion was running great minutes before it died, I suspect a “simple” issue here, but I’m not seeing it yet.
Will have a scantool on Saturday.
Any other ideas?
post #10 of 14 Old 04-12-2013, 12:10 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Are you running OEM oil filter and filter cap? I'd start there after what you said about your low pressure slowly rising then dropping again. If that's not it I'd suspect hpo leak somewhere but it's like a needle in a hay stack without a monitor or autoenginuity for your laptop. Btw the torque app is for android devices only so if you have a iPhone it won't work.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
