Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 09-11-2006, 10:12 PM
hayder1 hayder1 is offline
Cool 6.0 power loss
Hi, Ive got an 03 6.0 psd,45k miles,stock, and it seems to rev out with no power going to the ground when I start out in the mornings after she warms up, I've tried cooling it down and shutting it off then restarting it, And thing were good again, This is the 3 time around with it in different states, Any thought's Thanks
Hayder1 03 f350,
Old 09-11-2006, 10:21 PM
mschn99 mschn99 is offline
so you have no power warm, it runs fine on initial start up?? Also, has there been any check engine lights or any other issues to note besides the lack of power?? do you have gauges and whats the boost look like if you do??
Old 09-11-2006, 10:57 PM
Cool
Hi Mark, It starts fine, then once your on the highway she seems to rev up 3000 goes through all the gears and tops out at 60-65 mpr, Then I shut it down restart and things are fine, I had the vgt actuator and the egr valve replaced, the check engine light was going off and on at different times then off after the dealer fix, Other then that it seems fine, Thanks again Darcy
Old 09-11-2006, 11:09 PM
Cool
Mark, I forgot about the boost, I have no gauges yet but ford is saying the boost on there road test was 25.5 psi? I hope this helps, Darcy
Old 09-12-2006, 07:32 AM
almost sounds computer related....no other symptoms to speak of??
Old 09-12-2006, 09:35 AM
Cool
Mark, today I fired it up, there was grey/black smoke 3-5 seconds, then it cleared and ran great! Other than that it drives and sounds fine, Thanks Darcy
Old 09-14-2006, 05:20 PM
wetnwild wetnwild is offline
power loss in 2005 6.0
my truck bucks and hicups around 45 to 50 mph has anyone else had this problem?
Old 09-14-2006, 09:39 PM
Cool
No I havn't seen that yet, I have the truck booked in for a reprogram next week, I'll post the results, I'll ask the dealer if they heard of the bucking problem, Darcy
Old 09-19-2006, 08:36 PM
OK Just got the truck back from the dealer and they say there is a temp sensor that only allows the turbo to produce a certain amount of boost to save the motor from damage due to cold temp 's on start up, Sounds good, but the truck was warm to begin with so I think the sensor may be failing. Any comment? Thanks Darcy
Old 09-19-2006, 08:42 PM
find another dealer, your getting fed a load of bull
